How many watts per channel it show 150w on the back
  • David Dunn
    David Dunn Apr 01, 2011
    what product? If it's total power consumption by the unit that is NOT watts per channel but it does Wmply a maximum because you can't have more power out than goes in, plus power is lost to heat and stuff.
    read this discussion...
    http://answers.yahoo.com/question/index?...
    Take claimed WPC with a HUGE grain of salt.
    Sergeant:
  • 298 Answers
There could be several answers to this question depending on where the figure 150w appears and what other information is with it.
If the figure is next to something like AC100v or 220v then this is the mains power consumption rating - there is no direct correlation to output power because it will depend on the other components in the system and how they are configured.
If it is on the output stage of the amplifier (where the loudspeakers connect) then it could be a either the total of all the channels added together or a per channel rating. If it is an output power it will normally also have the word "at" followed by another number and the symbol ω (or the word ohms). The actual output achieved will vary depending on the resistance of the loudspeakers (for example an amp rated at 150watts at 8 ohms would only be able to push about 75 watts into 16 ohms but 300 watts into 4 ohms)
Further the rated power could be quoted either in Peak output (also known as peak music power or pmp) or, alternatively it may have the letters RMS (Root Mean Square) which roughly equates to 300watts Peak.
Cheaper units tend to quote Peak outputs because it makes them look more powerful than they really are. RMS is generally the power output rating used by high quality equipment and professional musicians because it gives a better indication of general usable power.
Posted on Apr 01, 2011
How many watts does a sony xm-4301have?
it is a 4 channel amp, rated at 30c/60peak x 4 channels @ 4 ohms. bridged to 2 channels, it can deliver 70 w 2x continuous@ 4 ohms pr 150w x2 peak @ 4 ohms
below is the users manual
http://www.eserviceinfo.com/download_start.php?downloadurlid=57827
Aug 23, 2014 | Car Audio & Video
I have a audition 150 watts x 2ch bridgeable high power amp serial # 00400274 need size of inline fuse. does not show size of fuse on diagram
hi.
if it is 150 watts TOTAL power then you should use a 15 amp fuse.
(150w / 12v = 12.5amps, 15amp fuse should provide the correct protection.)
if the system is 150 watts PER CHANNEL. then it will be 300 watts total and a 30 amp fuse should be used.
(300w / 12v = 25 amps. 30amp fuse should be used.)
30 amp is normally the highest fuse recommended for an car audio system, so i would not use higher than this without taking the unit to a qualified auto electrician, to get the system checked for safety. if you have any further questions please feel free to ask.
Jun 07, 2011 | Car Audio & Video
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
What is the total WATT output on the Sony MHC-G101 mini hi-fi 3 CD changer, dual cassette home component system? I misplaced the owner's manual, and I want to know how much power it has. // Tks
According to page 24 of the manual, it delivers 11 Watts RMS (route mean squared) per channel into 8 ohm speakers.
Elsewhere in the manual, you'll see references to "15 watts per channel" and as much as "25 watts per channel". The 15 watt value is valid when putting up with some 10% THD (total harmonic distortion), this value is 11 times higher than the .9% THD value given for 11 watts per channel. You tolerate .9% THD now, but you wouldn't want to listen to anything with 10% THD. The 25 watts per channel is what they call "Music Power". Watts is an electrical term, "music power" is not. You could use it to compare other devices that only offer "music power" values, but the best indication of how it will perform is based on watts in RMS, into an 8 Ohm load (most speakers are 8 ohms). The lowest THD values are best.
From the manual:
AUDIO POWER SPECIFICATIONS
POWER OUTPUT AND TOTAL HARMONIC
DISTORTION:
With 8 ohm loads, both channels driven, from
70 - 20,000 Hz; rated 11 watts per channel
minimum RMS power, with no more than
0.9% total harmonic distortion from 250
milliwatts to rated output.
I hope this helped!
Nov 23, 2010 | Sony MHC-G101 Shelf System
External amp with 901" eq
BUY A SHERWOOD STEREO RECEIVER 100 WATT PER CHANNEL AT RADIO SHACK WHICH HAS A TAPE LOOP FOR 901'S AND A TURNTABLE INPUT ALSO. COST $100.00.
Jan 14, 2008 | Bose 901 VI Main / Stereo Speaker
Inquiries
Straight from the product's manual...
Amplifier section
Power Output-
[Stereo Mode]
125 watts per channel
[Dolby Pro Logic Mode]
Front
120 watts per channel
Rear (Surround)
60 watts per channel
Center
120 watts
Click HERE for the manual.
There you have it.
Cyryl
Nov 10, 2007 | Aiwa AV-X220
59 people viewed this question
 Grubhead
Grubhead
