Question about Keurig B50 Coffee Maker
Says ready but does not brew and reverts immediately to ready...also menu button not working
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Apr 01, 2011
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
I set the brew size on the Keurig, but can't figure out how to get the lights to stop blinking and make the coffeemaker actually brew me a cup of coffee. I've held down the brew button, thinking that would...
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
Dec 18, 2010 | Keurig B70 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
Aug 10, 2009 | Keurig B60 Coffee Maker
Menu cycles through the options non-stop
Have you tried unplugging the unit? Sometimes the machine will get caught in a repetitive "cycle" and needs to be re-set. If this does't work, let me know
Feb 21, 2009 | Keurig B50 Coffee Maker
Keurig B70 Not Ready Message
Unplug the unit for 20 seconds- 1minute. Plug it in again. You should be able to program from the menu. Hope this works.
Feb 12, 2009 | Keurig B50 Coffee Maker
WARMING PLATE DGB 300
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing.
Feb 01, 2009 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Reset Procedure?
I have a B60 and it does not have the "NOT READY" problem when I did the "priming" process. So I brought this B70 during Christmas this year, I had the exact "NOT READY" problem during the "priming" process like most of the people here. They sure DO have some engeineering/quality control issue here. No water was coming out and it looked like the pump had some kind of problem in getting water from the tank when the "priming" process was taken place. Instead of waiting a technican to call me back on Monday, I decided to ask my friend Google. It appeared there are a lot of people have the same problem and only ONE of the postings offered a solution and it WORKS!!! Here is the link and the extracted method in showing you how to reset the B70 so that you can retry the "priming" process. PS: You may have to try MANY times for the step #3 as described. http://www.all-about-coffee-makers.com/my-experince-of-keurig-b66-coffee-maker.html Fixed Not Ready Mode by: Anonymous Bummed - I talked to Keurig this morning (Dec 27, 2008). There are 4 steps to fix this: 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen. 2. Press "menu" once. Your LCD screen should say Brew 0:00. 3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly. 4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
GOOD LUCK :o)
Posted by: Harry at December 28, 2008 10:05 AM
Jan 10, 2009 | Keurig B60 Coffee Maker
No ready que
I received my B60 from Ebay and when it came the "not ready" message was blinking. I called the company and honestly told them my problem and also mentioned that it was an Ebay purchase with no warranty. They fixed my problem for free anyway, and were very friendly. I will definitely consider purchasing more from them in the future based on this experience. We reset my machine by doing the following two steps:
1. Press the small and medium cup buttons at the same time then immediately press the menu button three times.
(the number listed there showed how many cups of coffee the machine had made--mine said 0:04 which was four cups)
2. Hold the medium cup button and hit menu button then the small cup button quickly while still holding the medium button then release the small and medium quickly.
Jun 09, 2008 | Keurig Special Edition B60 Coffee Maker
Keurig B50 Coffee Maker Logo
218 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
