Question about Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700
We have a Trilogy lock that when you turn the handle from the outside and push down, the plunger only goes in 1/2 way. When you lift up - it works normal.The inside handle retracts the plunger both (up and down) ways just fine.Everything else works normal. Is there something worn out?
  • 963 Answers
I've included a link to the installation instructions for the DL 2700 lock, which is a PDF file requiring Adobe Reader or similar program be installed to open the PDF:
http://napcosecurity.com/download/DL2700_WI835_INST.pdf
Scrolling down to page 8 of the instructions (Troubleshooting) indicates that if the lever will not fully retract, then the lock is either not full engaged with the latch or is misaligned, or that the lock is not centered on the door.
This link:
http://alarmlock.com/tech_library_instruction_manuals.asp
takes you to the tech support page, where you can find more documentation or contact their Customer Support directly.
Posted on Apr 10, 2011
Remove the lock from one door if I can't access the inside of the door
There should be a manual key override just for situations like this. You will not be able to uninstall the lock from the outside. That would defeat the purpose of having a lock at all. You have to be able to gain access to the backside of the lock. The side that would have the batteries.
Jan 18, 2015 | Trilogy Locks & Locksmithing
Why does my onity ht24 lock not open when the handle is pushed down? it always works when the handle is lifted up but almost never when the handle is pushed down.
The lever return spring might be weak or broken. Lift the lever slightly and then push down. If it opens, that's the problem. If it still won't open, something else might be broken or badly worn. The handle is pushed down far more often than it's pulled up.
Apr 29, 2014 | Locks & Locksmithing
Driver side door is frozen open with lock closed. Try to close door and it bounces back. Unlocking with key or with auto-lock does nothing. Key turns, lock button goes up and down, but mechanism does not...
Give the locking "jaws" a good dose of WD-40 and start with a pair of pliers ans working the door handle get the "jaws" moving and work it a lot while keep dousing it with the lubricant. Worst case scenario would be that the spring that opens the jaws is broken and will need replaced. Please rate this answer, thanks.
Feb 06, 2011 | Ford Taurus Cars & Trucks
The cable system on the pop up assembly is not working. lifting up or pushing down on the stem does not engage the plunger(in the sink drain).
One of two things can be wrong.The first is the drain plug itself has become disengaged with the plunger inside the drain line. You can check this by pulling up on the drain stopper itself, if it comes all the way out then all you need to do is to reinsert it and give it a little twist to get it reseated on the plunger hook. The other may be the drain handle on the top of the faucet may be disconnected from the rod. Open up the doors underneath the sink and inspect it. The rod should go down and the plunger handle should connect to the rod via a bent metal clip. Ensure it is in the correct position to activate the handle in the drain pipe when the top is pulled up.
Nov 29, 2010 | American Standard Swan 4 In. Bathroom...
Cant find any thing in bowl ,replaced air tank drain is clear and still does not flush replaced bowl and flushes this is the 4th toilet with same problem cant find anything in any bowl we changed
Try turning off the water to the toilet, then old the handle down until you hear that all the
water has drained out of the tank. Then turn the water back on. Then take a cup of water
and put water on to the plunger on top of the tank. Check for air bubbles, if there are bubbles
then that is the problem. The tank MUST HAVE a certain amount of air in the top of the tank,
or it will not work at all. You might have to remove the plunger assembly and put some vaseline on the big O ring seals. To remove the plunger, take the screws off the stainless bent rod that goes
over the plunger, then remove the rod, or just move it out of the way. The plunger can be removed
by sticking the jaws of a pair of chanel lock "pump pliers", then grab the handles of the channel locks and turn the plunger assembly out.
Sometimes all you need to do is drain the tank down, and the toilet might work for a long time.
It's such an easy fix, a person really doesn't mind draining the tank.
Hope this helps
LeRoy Wolff , North Dakota master plumber # 8401
Nov 01, 2010 | Sloan M-101526-F Flushmate?® Complete...
94 chevy lumina apv door will not open most of the time
since it is the drivers front door it could be the outside door handle , the rod that goes from the handle to the lock asbly or the lock asbly its self take the door trim panel off and then loos inside the door and latch the door with the door open. open the door with the outside door handle and watch the rod and the lever that the rod is pushing down the lever might not be pushing the lever down far enough to release the lock. If the lock does not open try pushing down on the lever and see if the lock releases if it does ck the outside door handle for cracks along the hinges of the handle I have found that most of the time that it is the outside door handle cracked and the rod is not moving the lever far enough to release the lock.
Feb 20, 2010 | 1994 Chevrolet Lumina APV
No instuctions for my arctic twister which was given to me as is
This product wastes a lot of ice cream in its mechanisms. I would not reccomend its use to anyone who believes in "waste not..."
Here are the instructions for any wasteroos who would still use this product:
Série IC200 Series
Arctic Twister™
Ice Cream Mixer
? U.S.A./Canada 1-800-231-9786
Mexico 01-800-847-2309
www.blackanddecker.com
To Assemble the Ice Cream Mixer:
1. Insert the Twister firmly into the opening on the
Base (A).
2. Slide the Chute/Dispenser over the Twister along the runner
on the Base (B); it will click into place.
Note: Unit will not operate if Chute/Dispenser does not click
into place.
3. Hold the Lid with Ratchet Clip in one hand with the Handle
facing front. With one finger, push the Ratchet Clip on the Lid
forward. In other hand, hold the Plunger with smooth side
facing front, and from underside of Lid, insert Plunger into
Clip opening (C), pushing Plunger up until the Ratchet Clip
rests on top of the Plunger base.
4. Set aside the Lid with Plunger in place. Now you're ready to
start mixing up some fun and delicious ice cream treats!
To Use the Ice Cream Mixer:
Assemble all ingredients before you begin to make your first
batch of twisty treats: Set out an ice cream scoop, the mix-ins
you plan to use, ice cream cones, cups or dessert dishes,
then bring out the ice cream.
For best results, use hardened ice cream, frozen yogurt,
sorbet or sherbet directly from the freezer.
You may want to rinse off the Lid, Plunger, Chute/Dispenser
and Twister before beginning new ice cream flavors or
mix-ins.
Always wash Lid, Plunger, Chute/Dispenser and Twister
between batches, if you have been using ice cream or mix-ins
containing peanuts, to prevent accidental peanut
consumption by those who may be allergic to them.
1. Plug the Cord into a standard 120V wall outlet.
2. Position a flat-bottom cone, dessert dish or cup under the
spout of the Chute/Dispenser.
3. Place 1 scoop of store-bought ice cream into the
Chute/Dispenser. Sprinkle in 1-2 tablespoons of the mix-ins
(see "About Mix-Ins"); add another scoop of ice cream, and
continue layering as above, ending with ice cream, until
Chute is filled.
4. Fit the Lid with Ratchet Clip and Plunger in place (see
assembly instructions #3 above), onto Chute opening,
pressing down slightly and turning the Lid to the right to fit
into position, then to the left to lock it into place on the Chute.
5. Gently pump the Handle up and down a few times to "prime"
the Chute.
6. Press the On/Off Switch to "on" position, then slowly pump
the handle to move ingredients down the Chute. As you
pump the handle, the ingredients will automatically be moved
into the Twister, then out the spout of the Dispenser.
7. When the Chute is empty, turn On/Off Switch to "off" position.
Push the Ratchet Clip forward and pull up the Plunger, then
use the Handle to move the Lid to the right. Lift the lid with
the Plunger in place out of the Chute.
8. Repeat steps 2-6 to make as many batches as desired.
Jul 06, 2009 | Black & Decker IC200 Arctic Twister 2.11...
Rear door stuck on 1997 Pathfinder...Have
go inside, lift on handle, then beat the **** out of the door pounding it like your trapped in it trying to get out. latch mechanism is probably corroded and froze shut. once open, spray with wd40 and work the lever a lot. then get door panel off to see if handle is broken inside
Jun 16, 2009 | Nissan Pathfinder Cars & Trucks
2000 Dodge Caravan Rear Door Latch
I had the same problem and fixed it using the following steps. I am not an expert or even very mechanically inclined, just desperate to get this fixed without spending any money. This was done on a 1996 Dodge Caravan. Similar steps should apply to a number of years of the Caravans and Voyagers.
Two people will make removing the panel easier. To do this, you'll need a phillips screwdriver, penetrating lubricant, and pliers.
First, if you cannot open the door at all: There is a small plastic disc plugging a hole just above the latch on the inside. Pop out that disk, and use a screwdriver to lift the latch mechanism. It should not take a great deal of force to move the latch. When the latch moves, push the door and it should open.
1. Remove the plastic panel on the inside of the van. You need to remove the handle and several screws on the perimeter of the door.
2. Disconnect the interior door lights by gently pulling the wiring harness (two of these).
3. Looking at the door from the interior, there is a small electronic plunger mechanism on the right side with an "accordion" (this is the electric lock). There is a rod that goes from the to the middle of the door, just above the lock mechanism. Another rod goes from the key lock to the latch. This rod, threaded on one end, snaps into a small bracket on the latch. It may need to be snapped back in. There may also be a rubbery/tar-like sticker near the locking mechanisms that can be removed (it can interfere with some of the moving parts).
4. Manually operate the plunger on the electric lock several times using pliers. Mine was extremely stiff. It should move the rod at least a full inch.
5. Spray lubricant on the latch, the back of the key lock, and the back of the exterior handle. Also spray lubricant into the key lock itself (where the key goes). Do NOT spray lubricant on the electronic lock mechanism or plunger.
6. Just above the latch, there is a small hole (only about 1/8" around). Carefully and liberally spray lubricant into that hole in every direction (this is where the rods from the key lock, electric lock, and latch meet). There is a white plastic post that comes out through another nearby hole. Spray lubricant liberally into that hole, too.
7. Again, manually operate the plunger on the electric lock several times using pliers. It should be considerably smoother to operate.
8. Put your key into the key lock and pull it out several times.
9. Spray lubricant into the key lock again, then carefully operate the lock with the key. If it didn't work or was stiff before, it should operate much more smoothly. Operate the electric locks several times.
10. When operating the lock, you should see the plunger on the electric lock move to its extents (at least an inch). Watch it when using a key and using the electric lock.
11. Check the movements of the rod and plunger when operating the lock, and the movements of the latch when operating the handle (when unlocked). If anything is still really stiff, use some more lubricant and operate the lock and handle again.
12. When reassembling the door panel, remember to plug in the two wiring harnesses for the interior lights.
I hope this helps!
Jul 06, 2008 | 2000 Dodge Caravan
Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700 Logo
289 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
