Question about Car Audio & Video
My radio keeps showing wait 1 hr - Car Audio & Video
  • 4,919 Answers
It is because you are entering a wrong code
The radio SERIALNUMBER is required for a code b> First remove the radio from the dashboard. b> Then post the radio make+model plus all theletters+numbers on any labels,barcodes or stamped in the metal casing. This information can then be used to see if a code can becalculated b>
Posted on Apr 01, 2011
Sat. 01 sl wait 1/2 hour to start when warm. stalls when ideling 1/2 hr restart
You have a bad air intake manifold gasket. If it runs idling high, take a can of brake cleaner and spray it on the air intake manifold by the firewall. Spray it right where the air intake bolts on. There are 8 10mm bolts or nuts there. When you spray it while idling, the revs will come down. This makes sure that is the problem before you go any farther. My 02 did the same thing.If you need to know how to change it, let me know, I can walk you through it. It's a one to two hour job, b ut easy
Dec 14, 2014 | 2001 Saturn L-Series
Im still waitin for someone to help me with unlockin my stereo on my 98 Lumina
to unlock radio.if you dont have no code wrote down.try this procedure. first write down any three or four digit number from 000 to 1999 and keep it in a safe place separte from the vechicle. turn the ignition to ACCESSORY or RUN. turn the radio off. press the 1 and 4 buttons together. hold them down until - - - shows on display. next you will use the secret code number which you have written down.press MN and 000 will appear on the display. press MN again to make the last two digits agree with your code.press HR to make the first one or two digits agree with your code.press AM FM after you have have confirmed that the code matches the secret code you have written down.the display will show REP to let you know that you need to repeat press MN and 000 will appear on the display. press MIN again to make the last two digits agree with code.press HR to make the first one or two digits agree with your code.after that repeat press AM FM and this time the display will show SEC to let you know that your radio is secure. the the indicator by volume control will be flashing when the ignition is turned off.IF ALL FAILS DEALERSHIP NEED TO RESET RADIO CODE..
Mar 11, 2013 | Cars & Trucks
How do i unlock the radio
You can enter the un-lock code provided with your radio by doing the follwing:1 - Turn the ignition to ON, the radio should show LOC2 - Press MN (000 will appear on the radio display)3 - Press MN again to make the last two digits match your radio unlock code4 - Press HR to make the first 2 digits match the radio unlock code5 - Press AM-FM to unlock the radio
If the code is entered correctly the radio will display SEC
Feb 12, 2012 | 1999 GMC Envoy
The battery was disconected and now when i turn on the radio it says wait 1 hr
Yes on some vehicles you have to leave the ignition on. If you turn off beforehand you must wait all over again. Will ask you for a code normally after this time has elapsed.
Good luck with it.
Apr 01, 2011 | Car Audio & Video
Hi, my blaupunkt radio is displaying wait 1 hr, cant shift it. any solutions please.
WAIT 1 HR means wrong codes have been entered previously
To restore, leave SWITCHED ON ..UNDISTURBED for as long as it takes to automatically reset itself
In this case it should be 1 hour
Make sure you have the correct code
Feb 01, 2011 | Blaupunkt San Remo CD32 CD Player
Radio locked no code
Unlocking the Delco Radio Theft-Deterrent Feature After a Power Loss
If you know the code that was used to lock the radio then use the following instructions from the owner's manual to unlock the radio.
Quote:
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again until the last two digits agree with your code.
4. Press HR until the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches your secret code. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
If you don't know the code that was used to lock the radio then you will have to use the dealer's unlock procedure as follows. The dealer code changes over time - the one listed is current as of this posting. If it doesn't work try 08359 or search the forum for messages with a more recent code.
Quote:
1. Press and hold presets 2 & 3 for about 10 seconds until the first three digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM-FM button, write down the next three numbers.
4. Call 1-800-537-5140. When asked, enter dealer code 202108, press the * button, and enter the six digit code from the radio. You will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first two numbers, press the MIN button and set the next two numbers, then press the AM-FM button. The display will show SEC, indicating the radio is now operable and secure.
To remove the code, repeat step 5. you should see --- on the radio face indicating the code is now out of the radio."
Dec 29, 2010 | 2000 GMC Jimmy
2000 Chevrolet Lumina Unlock radio code
If you have the security code it's easy. The code is something that either you or a previous owner entered. If you don't have the security code a trip to the dealer will be in your future.
Unlocking the Theft-Deterrent Feature After a Power Loss
Enter the code as follows; pause no more than 15 seconds between steps.
  1. Turn ON the ignition. LOC will appear on the display.
  2. Press MN and 000 will appear on the display.
  3. Press MN again to make the last two digits agree with your code.
  4. Press HR to make the first one or two digits agree with your code.
  5. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is now operable and secure.
Entering the incorrect code eight times will cause INOP to appear on the display. Wait an hour with the ignition in the ON position before you try again. When you try again, you will have three more chances (eight tries per chance) to enter the correct code before INOP appears.
Deactivating the Theft-Deterrent Feature
  1. Turn the ignition to ACC or ON.
  2. Turn OFF the radio.
  3. Press the 1 and 4 buttons together. Hold them down until SEC shows on the display.
  4. Press MN and 000 will appear on the display.
  5. Press MN again to make the last two digits agree with your code.
  6. Press HR to make the first one or two digits agree with your code.
  7. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show -- -- --, indicating that the radio is no longer secured.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered.
Dec 27, 2010 | 2000 Chevrolet Lumina
Keeps showing paper jammed, but no paper in it
just oil the paper feeder and wait for 24 hr. and you can start printing.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 25, 2010 | Canon Pixma MP450 All-In-One InkJet...
Sep 14, 2010 | Canon Pixma MP450 All-In-One InkJet...
Changing battery 2001 Lumina and radio lock up.
someone (hopefully you) set the 3 or 4 digit security code on the radio. when power is disconnected, like if someone steals your radio, the radio locks and cannot be used. the code can be from 000 to 1999. the hour and minute buttons are used to enter the numbers. 2000 choices - good luck
to unlock the system:
1 turn on ignition - LOC will appear
2 press MN and '000' will appear
3 press MN again until you see the last 2 digits of the code you want to try
4 press HR until you see the first 1 or 2 digit of the code you want to try
5 press AM FM
6 SEC will appear if you got it right - LOC will show if you got it wrong
good luck
Sep 26, 2009 | 2000 Chevrolet Lumina
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
