Question about Refrigerators
I have a candy fridge freezer - the freezer is fine. When the fridge to turned up to max - the food in it is not cold. How can I resolve this? If I defrost the fridge - could this help? Thks
  • 132 Answers
Defrosting the freezer will temporally solve the problem. There could be a problem with the defrost cycle or the evaporator fan. a technician can help you there
Posted on Apr 01, 2011
My candy fridge freezer fridge part is freezing! the light keeps clicking on and off. The food is either frozen or warm. never cold as usual. I would like to know if i need to buy a new one. It is 7 years...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jun 30, 2011 | Candy CPCA240FFK Bottom Freezer...
My Frost Free Fridge-Freezer has a problem. Upper portion, freeze all the fruits and vegetable, and lower portion not freezing any poultry meat etc. We have contacted a local dealer, and he need spare...
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check the cold control and the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout .....
Aug 08, 2010 | Refrigerators
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Refrigerators
Freezer cold, not fridge
24 hours It should be good Do check temp settings.
Aug 05, 2009 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer
it seem to me that the gas lewel are low in the system
Jun 16, 2009 | Refrigerators
Freezing frosting fridge
i had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Jan 10, 2009 | Candy CPCA240FFK Bottom Freezer...
GE fridge GDS 18 LBR
Have u check the moisture control in the frezzer? If so make sure that all the vents are clear of all food and/or food containers and such... Turn ur fridge temp control to max.. Wait 5 hours WITHOUT opening fridge or freezer. Good luck! Let me know how everything tur out
Nov 10, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Candy frost free fridge freezer
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Things freese-up in the kenmore fridge
Try turning down the unit a half knotch, 1 full knotch at MAX, the cold air comes from the freezer to the refrig(fresh food) section, its rolls up the back of the wall to circulate it
A fridge that is to cold is usually shown when food nearest the back wall freezes( i get this call plenty times a day, this is the fix)
recommened freezer temp 0-5, fresh food(refrig) temp is 32-40
May 02, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
