Question about Car Audio & Video
The battery was disconected and now when i turn on the radio it says wait 1 hr
    Scholar:
  • 116 Answers
Yes on some vehicles you have to leave the ignition on. If you turn off beforehand you must wait all over again. Will ask you for a code normally after this time has elapsed.
Good luck with it.
Posted on Apr 01, 2011
24 volt, 172-743240
Sometimes, the charger will overheat and fail. Try unplugging the charger overnight, plug it back in the next morning, then place the battery in the charger after waiting a few moments. Normally, this will correct the charging discrepancy.
May 24, 2014 | Garden
I used a wrong code on my ford ranger V6 Radio, how do I get it fixed?
wait 3 hours input correct code or try disconecting battery 1 min then try code
Sep 23, 2013 | 2004 Ford Ranger - SuperCab, 6 short bed,...
My radio keeps showing wait 1 hr
It is because you are entering a wrong code
The radio SERIALNUMBER is required for a code b> First remove the radio from the dashboard. b> Then post the radio make+model plus all theletters+numbers on any labels,barcodes or stamped in the metal casing. This information can then be used to see if a code can becalculated b>
Apr 01, 2011 | Car Audio & Video
Hi, my blaupunkt radio is displaying wait 1 hr, cant shift it. any solutions please.
WAIT 1 HR means wrong codes have been entered previously
To restore, leave SWITCHED ON ..UNDISTURBED for as long as it takes to automatically reset itself
In this case it should be 1 hour
Make sure you have the correct code
Feb 01, 2011 | Blaupunkt San Remo CD32 CD Player
2000 saturn radio is locked. how do i unlock
1.) To begin, if your radio is displays LOC, then proceed to step 2. If your radio says INOP, then turn your ignition to the RUN position, and turn the radio ON. You must leave it like this for a minimum of 1 hour (not 59 minutes) to clear the INOP message. I would wait 1 1/2 hours just in case doing it too early causes the timer to start over.
2.) Turn your ignition to RUN (if not already), and your radio to OFF. Press and hold preset buttons 2 and 3 for around 5-10 seconds to obtain a scrambled version of your radio's original factory set code.
3.) Call a GM dealer with this code. Tell them you are with a local shop i.e. I am Joe with Good Year Highway Tire; Then tell them: We have a 2000 Saturn SL we just changed a battery in and the radio is now locked. My mechanic pulled the pre-code. Could you give me the code? This usally works at no charge.
Once you have the code write it down. Keep atleast 2 copies. Hope this helps!
May 06, 2010 | 2000 Saturn SL
My vw radio is in safe mode
disconect bettery for 4 hr than try againe
Sep 11, 2009 | 2000 Volkswagen Beetle
Check engine light is on even after I changed the TCM wich is the transmission control modual
Remove the negative cable from your battery and wait 1 hour the car computer will reset, be carefful that your radio is not anti device, otherwise you would need the code to reset your radio which is a four number code.
Good Luck!
Jun 26, 2009 | 1999 Mitsubishi Montero Sport
Problems with downloading
Delete the one you downloaded.
Disconect camera from usb.
Re-Download and wait , after re-boot.
Open easyshare wait. conect camera to usb.
Read again manual and help topics.
Vitally
Jan 26, 2009 | Kodak EasyShare EX1011 Digital Picture...
Stereo
If it's in safe 2 it's locked. With a battery charger on put the key on handbrake on to take off daytime lights if you have them. Turn the radio on for an 1 hr to 1 hr 1/2 until the display reads 1000. Enter your radio code and your set.
Oct 16, 2008 | 1999 Volkswagen Passat
Delco Car Radio
When battery power is removed and later applied to a
secured radio, the radio won’t turn on and LOC will
appear on the display.
Unlocking the Theft-Deterrent Feature After a
Power Loss
Enter your secret code as follows; pause no more than
15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MN and 000 will appear on the display.
3. Press MN again to make the last two digits agree
with your code.
4. Press HR to make the first one or two digits agree
with your code.
5. Press AM-FM after you have confirmed that the
code matches the secret code you have written down.
The display will show SEC, indicating the radio is
now operable and secure.
If you enter the wrong code eight times, INOP will
appear on the display. You will have to wait an hour with
the ignition on before you can try again. When you try
again, you will only have three chances to enter the
correct code before INOP appears.
If you lose or forget your code, contact your dealer.
Disabling the Theft-Deterrent Feature
1. Turn the ignition to ACCESSORY or RUN.
2. Turn the radio off.
3. Press the 1 and 4 buttons together. Hold them down
until SEC shows on the display.
4. Press MN and 000 will appear on the display.
5. Press MN again to make the last two digits agree
with your code.
6. Press HR to make the first one or two digits agree
with your code.
7. Press AM-FM after you have confirmed that the
The display will show ---, indicating that the radio
is no longer secured.
If the code entered is incorrect, SEC will appear on the
display. The radio will remain secured until the correct
code is entered.
Theft-Deterrent Feature (If Equipped)
THEFTLOCK is designed to discourage theft of your
radio. It works by using a secret code to disable all radio
functions whenever battery power is removed.
The THEFTLOCK feature for the radio may be used or
ignored. If ignored, the system plays normally and the
radio is not protected by the feature. If THEFTLOCK is
activated, your radio will not operate if stolen.
When THEFTLOCK is activated, the radio will display
LOC to indicate a locked condition anytime battery
power has been interrupted. If your battery loses power
for any reason, you must unlock the radio with the secret
code before it will operate.
Activating the Theft-Deterrent Feature
The instructions which follow explain how to enter
your secret code to activate the THEFTLOCK system.
It is recommended that you read through all nine steps
before starting the procedure.
If you allow more than 15 seconds to elapse between
any steps, the radio automatically reverts to time and
you must start the procedure over at Step 4.
1. Write down any three or four-digit number from
000 to 1999 and keep it in a safe place separate
from the vehicle.
2. Turn the ignition to ACCESSORY or RUN.
3. Turn the radio off.
4. Press the 1 and 4 buttons together. Hold them down
until --- shows on the display. Next you will use the
secret code number which you have written down.
5. Press MN and 000 will appear on the display.
6. Press MN again to make the last two digits agree
with your code.
7. Press HR to make the first one or two digits agree
with your code.
8. Press AM-FM after you have confirmed that the
The display will show REP to let you know that you
need to repeat Steps 5 through 7 to confirm your
secret code.
9. Press AM-FM and this time the display will show
SEC to let you know that your radio is secure.
The LED indicator by the volume control will begin
flashing when the ignition is turned off.
Jun 01, 2008 | Car Audio & Video
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
