Question about Panasonic NN-T888S Convection/Microwave Oven
Inside the NN-C2003S microwave on the right hand side is a paper like material that has deteriorated (90 mm long and 30mm high) and exposed an opening. Where can I buy a replacement cover or can I use any non-metal material?
It's made of milar from memory. 4 years ago I needed a new one as well as a magnetron and the ceramic tray, and even though I live in Sydney, LCS Electronics in Western Australia were by far the cheapest for the parts. Back then I think the milar was around $8.
Posted on Apr 14, 2011
Where can I get the membrane and digital unit board for model NN-C2003S? Please provide the website.
If you can tolerate the time and cost of international shipping, contact www.fixyourboard.com
They repaired my 20-year old wall oven control board and shipped it back to me with 1 year warranty. Works like new.
Jan 19, 2018 | Microwave Ovens
How do i change the turntable motor on a sears 72163259301
Go to the bottom of the oven - they have several side-by-side holes that when you cut through the little bit of material between the holes, allows you to create your own door - inside should be your turntable motor - Again this is a standard type location - Commercial units may not have turntables, but the 'stirrer' is instead located below the plain table on which you rest your food
May 10, 2014 | Panasonic NN-H965 Microwave Oven
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Jan 08, 2013 | Microwave Ovens
Sharp Carousel microwave - 1200 watts - Model R530EKT - caught on fire while using
you must carefully and read your instr. manual if some material inside the microwave can be produce fire. Otherwise the microwave can be old and the electronic component deterioring and cause exploding.Some time the material inside from the microwaves, is corroded, and the irradiation can be produce Fire. Tes the indication given.
God bless you
Oct 01, 2012 | Sharp R-510HW Microwave Oven
I have a Panasonic NN-C2003S microwave/convection oven that won't heat anything under micropower mode and on countdown cuts out when it gets to 8 sec. It is working on the convection mode. Could someone...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional.
Hope that helps.
Jan 04, 2011 | Microwave Ovens
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Jun 06, 2009 | Panasonic NN-T990SA Microwave Oven
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Panasonic NN-T888S Convection/Microwave Oven Logo
201 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
