Question about Brother DCP 115C All-In-One InkJet Printer
DCP 115C does not print
This keeps flasjhing-"unable to print.see routine maintenance &trouble shooting in guide".
  • 659 Answers
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Posted on Aug 05, 2008
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Printer won't print
..if not mistaken, the error message is Unable to clean, which indicate you will need to replace the waste ink pad and reset the waste ink counter.. you will need to send to the local service centre to get it done..
May 24, 2010 | Brother DCP 115C All-In-One InkJet Printer
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
"Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Jul 11, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C
help me to install my brother printer DCP-115
May 16, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
230 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
