Question about Dell Inspiron 1545 Notebook
The cylindrical structure on the lower of screen along which the screen rotate or you can say along which the flap folds is cracked...what to do now please suggest as soon as possible
  • 661 Answers
You want my personal opinion? I'd go on Ebay and look for a replacement shell for your laptop. Just open your laptop and transfer all the computers guts and stuff into the new shell. If you can't do that, sorry you're SOL. I don't think there is any kind of adhesive that repairs that kind of plastic.
Posted on Apr 01, 2011
How do I keep the button down when screwing the camera on
I suspect that this is the tiny locating button that sits beside the screw on the tripod.
Check your manual to find out how to remove the quick release sled. There is usually a small lever that needs to be rotated out of position and the sled lifts out.
Once you have the sled out, turn it over and you should see a small flap of metal that can be folded up and this is the means by which you screw the threaded part into your camera. Once it is tight, flip down the metal flap and then refit the sled to the tripod , taking care to rotate the lever again.
Some tripod levers remain locked while the sled is removed and they slip back into place when it is replaced in the tripod head.
Hope this helps.
Sep 17, 2014 | Sunpak PlatinumPlus 6000PG 61" Tripod
HARD TOP WILL NOT GO DOWN. HARD TOP WILL STOP MID WAY THROUGH THE PROCESS.
Hi. There are 2 flaps, one left, one rights the fold back when the roof is retracted. they are triangular in shape, and fold in half just behind wher the rear windows should be. check that these have folded back, it is normaly the right side that does not fold. reposition this flap and if the roof works the a simple string correction will be needed.
Apr 03, 2014 | 2007 Volkswagen EOS Convertible
What is the proper way to stuff a sleeping bag into a compression sack?
Basically, just stuff the sleeping bag into the sack while rotating the sack slightly with each 'stuffing' to make sure you fill all the nooks and crannies. Then close the flap, over the opening, and cinch the straps as tight as you can. You can check out this video: http://www.youtube.com/watch?v=GolE9gg3GRo
Dec 26, 2012 | Camping, Backpacking & Hiking
My screen lights for about 2 seconds and then goes black. If I press the off button and then press it on, I get two seconds of screen (good quality) and then black again. It acts like a cold-solder fault.
My LCD had the same problem. I just finished changing the 25V 1000uF capacitor and now its working just fine. The capacitors are located on the board that have the power input. Check if any of the capacitors (the tall cylindrical structures) have bulging tops, if they do, try to replace them Please bear the polarity in mind when you play with capacitors.
Greg
Jan 11, 2010 | ViewSonic Computers & Internet
GLASS BROKEN ON MY FRIGIDAIRE PRO
Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Replace brake light on my 2002 Honda Oddesey passenger side
Open the rear hatch and remove the two taillight mounting screws. These screws are located behind two plastic flaps that are flush fitting and part of the tail light housing. You will need a small flat blade screwdriver to put under the edge of the flap nearest the light. Pry gently (but persistently) and the flap will open to reveal the screw head underneath. (The hinge of the flap is on the side nearest the hatch opening.) Remove the screws with a phillips head screwdriver or an 8mm socket. Now comes the tricky part. Wiggle/pry the taillight housing as straight back as you can. Keep pulling/wiggling until the forward clip releases. Once it does you will be able to access the bulbs by rotating the bulb holders counterclockwise. Pull the bulb straight up out of its socket. Replace with the new bulb. Note how the forward spear point clip fits into its socket at the forward outboard edge of the housing. Fit the clip and push forward on the housing until you can hear the clip snap into place. Replace the screws and fold back the flaps. You're done.
-T
Jan 15, 2009 | 2002 Honda Odyssey
Screen: fold out screen displays nothing till rotated 180 deg. but touch screen works
the latch which connect the small screen has a thin ribbon like cable running into the small screen. the cable seem to be cut or loosely connected. open it and chk you can fix it.
Jun 16, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Cracked Plastic Molding/Frame
of course it would.the crack weakens the integrity of the frame causing it to collapse soon.if you have still warranty on it, take it back to where you bought it and get something better.
Jan 07, 2008 | Televison & Video
Paper / Envelope feed
Envelopes Follow the steps below to load envelopes into this product. Lower the output tray and slide out the extension. Move the feeder guard towards you. While holding down its locking tab, slide the left edge guide so that the distance between the two edge guides is slightly wider than the width of your envelopes. Load envelopes short edge first with the flap side down, as shown in the illustration. Use the line on the feeder guard as the indicator when loading envelope. The right edge of envelope is aligned with the line on the feeder guard. Set the feeder guard back. Note: * The folding quality and thickness of envelopes vary widely. If the total thickness of the stack of envelopes exceeds 10 mm, press each envelope in the stack flat before loading. If print quality declines when a stack of envelopes is loaded, load one envelope at a time. * Do not use envelopes that are curled or folded. * Flatten the envelope flaps before loading. * Avoid using envelopes that are too thin as they may curl during printing. Extract from CX3200 user manual
Sep 25, 2006 | Epson Stylus CX3200 All-In-One InkJet...
Dell Inspiron 1545 Notebook Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
