Question about Exercise & Fitness
I have orbit ST 7550, it shows E2 when starts
THE FAN DOES NOT WORK
Since this is a low end fan from Home Depot I can only guess. If it has a remote, you probably need a new receiver in the fan.
Mar 26, 2013 | Hampton Bay 60 In. St. Regis Fan, Ancient...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Palm Tungsten e2 How to Replace battery
Here is a video on YouTube that shows you step by step instructions. They take you from start to finish. Good luck.
http://www.youtube.com/watch?v=caJVwecskho
Sep 20, 2009 | Palm Tungsten E2 Handheld
I'm trying to sync my E2 with the Desktop. It all works ok until it reaches the stage of the Palm showing"synchronising Tasks" white the Hot sync window on the PC shows "installing handheld applications" ....
If you are running 3rd party apps, your E2 is starting to reject them. Either hard reset your E2 and reload everything or lose it and get a Siemens SX66. I had an E2 and a Z22. Wouldn't have either now. My wife has an E. Too bad
Aug 23, 2009 | Palm Tungsten E Handheld
Lost autofocus on 40D when using ST-E2 and 2 580EX
Try taking the battery out and putting it back in. If that doesn't work try cleaning the len's contact sesnors with a pencil eraser.
Jun 23, 2009 | Canon EOS 40D Digital Camera
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
