Question about ViewSonic PJD5111 Projector
The temp/lamp light flash and the fan turns on for about a second then the unit shuts off.
I have the same problem, been workign on it for a week now... someone says the color wheel might be off thus, noit detecting the correct RPM of the color wheel, and you will have to open the machine up and re adjust by hand. im about to take it apart now... wish me luck
Posted on Jun 28, 2011
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Hi, I have a Christie RoadRunner L6 Projector. When I turn it on the lamp light turns red and it does nothing. This unit does have dual lamps and a lamp replacement lamp light as well. I figured if it was...
I have a Christie RoadRunner L8 that fires up,lamps turn on and about 5 seconds after the lamps fire up it shuts down and both the warning temp. and ready lights flash at the same time. It seems to me it must be a sensor that tells it to shut down thinking that the machine is too hot-all the fans work and all of the filters are clean and it is moving serious air any clue and if so where do I start to look for such items? Thanks in advance Kirk
Aug 16, 2010 | Christie RoadRunner L8 Multimedia...
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Temp light flashes tried unplugging it for a few minutes turned it on tries to power up but then power , lamp , temp lights flash for a few seconds then it shuts down and temp light stays on
It sounds like you have a thermal issue. The TV is getting too hot or the Thermal Fuse is bad. The thermal fuse detects the temperature in the TV and tells the TV to shut down if it thinks it is too hot. Most likely caused by poor ventilation or clogged fans from household dust. Try moving TV away from wall or cabinet first, if this does not fix the problem, clean ALL the fans in the TV. If problem still persists, replace the thermal fuse.
Oct 04, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lamp goes off and tv shuts down after lamp replacement
CK FAN on LAMP,or you could have problem with Ballast.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Turns itself off after 5 seconds of run time. will not stay on, cooling fans work, lights up screen and shows picture, then shuts off. light flash on front right corner.
Either lamp is failing (not covered under any warranty), or the ballast has failed. Or it may be a problem with the power supply, or even the fans... What is the picture next to the flashing light? If it's only the lamp light, then either lamp or ballast, if temp is flashing (the thermometer), it will be fans, temperature sensors, main board or power supply.
Apr 22, 2009 | Samsung HL-T5675S Television
Dlp samsung
There are instructions to replace the lamp in the user's manual. The light comes up but if the lamp has now already several hours of use the resistance of the lamp increases and shut down the power supply of the lamp. Second, the lamp power supply could be bad too, but lets be optimistic and just replace the lamp first.
Apr 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
ViewSonic PJD5111 Projector Logo
414 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
