My remote wont work
My remote will not work even though i changed the remote to a universal one.
I can operate the t.v. form the unit itself. What do i do?
  • Anonymous Aug 19, 2008
    Remote will not work. New batteries. Universal remote will also not work. Entered proper code. Still does not work.
For
Posted on Aug 26, 2008
    Problem Solver:
  • 11 Answers
Did you use the correct programming code?
Posted on Aug 05, 2008
Electricity went out, when restored remote does not work
One of two options here honey... the battery in the remote is flat and needs replacing or... the remote receiving device in the unit was blown, or now has no power to operate. Change the battery... replace the remote... if the problem remains then the problem lies in the controlled device itself. DO NOT attempt this repair yourself.
Mar 27, 2014 | Universal MX-900 Remote Control
Infrared indicator light will not come on all buttons flash multiple times
um..you wont see the infra red with the naked eye..you can only see it using nite vision style equipment..something that shows in monochrome which is that frequency..if it lights up it is supposed to be working..some need reset to the units in use when the batteries are replaced..use the search mode on it..
Feb 06, 2014 | Universal Urc R6 Avex Pre-Programmed...
Universal remote wont operate tv
Remote issues and answers:
If you are using a "universal" remote do not expect it to if it evenprograms to have all the functions you need or had with the"original" remote.
If you are searching for codes for a universal to program it: GOOGLE the modelnumber of the remote for "codes" or if you do not have the ownermanual GOOGLE the model number of the remote for "manual".
Some remotes have a search feature that allows you to try all codes on at atime.
Universal remotes are far from UNIVERSAL.
If you have a remote that does not work at all--have it tested first: a remotetester is used at many electronic repair centers and places like Radio Shack for example.
Point remote at the tester and press any button and a strip or light willflash----some digital cameras will also react on display screen to this.
If dead check the battery/s and the connections where they go and if only somebuttons have to be pressed hard the unit may have had something spilled on it:it can be taken apart and cleaned in a proper way to resolve this.
If it has been dropped it can also be taken apart to see if the infrared LED/sat its sending end have come loose from the circuit board inside the remote.
Lastly is the best argument for an original remote is on many sets even if itprograms it will just not have all the needed functions the original one had.
Many companies especially on units with DVD OR VCR built in change the codewith each model and or year as most of these are not actually made by thecompany whose name is on the unit.
Let me know if you have further questions and I will try to help.
Mar 31, 2012 | Televison & Video
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
My remote wont work my vcr/dvd combo. tried some codes but none worked. Both are made by Magnavox
I have found that most DVD/VCR combos operate on their own frequency bands and TV remotes and alot of the universal remotes will not code to these,try the original remote that came with your combo unit to operate the other units that you want to control. Good luck !
Nov 29, 2009 | Audio Players & Recorders
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
