Question about Biostar N68S NVIDIA MCP68S Socket AM2+/AM2 micro-ATX Motherboard w/Sempron LE-1250 2.2GHz CPU, Heat ... (COMBO6S1250)
I just finished building a PC using motherboard Biostar N68S, but it won't power up. When I push the power button, it only works for 1 second. Everything is connected. What seems to be the problem?
  • 516 Answers
Click this link and click the download now button and wait for 20 seconds to appear the download file now click to that then it's start downloading the document. After downloading open the file and read the instruction for power supply. In case the power supply working then check your motherboard manual and see to it that you installed correctly the switches like the power led, hdd led, reset switch and power switch. If you followed the manual but still no power, remove the CR2032 battery installed on your motherboard for about 10 seconds and put it back again then turn on your computer. After this test still doesn't turning on your motherboard is defective. Have a nice day.
Posted on Apr 01, 2011
  • 109 Answers
Try to verify these :
1- Check that all perepherals are connected correctly (HDD, Drives...)
2- Check taht the motherboard support the CPU you are using.
2- Check that the RAM is correctly inserted (use an other connection slot)
3- Check that the CPU is correctly inseted and that the FAN is correctly placed
4- Check all USB port, may be there is a short circuit.
5- Check your AC Power.
Good Luck.
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
Dec 22, 2012 | PC Chips Computers & Internet
How to connect panel 1 of n68s3+
pin #'s
Dec 22, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I have bought 2 Biostar N68S motherboards for HTPC builds. Both of them have the same CPU and RAM. Neither of them will show any VGA output, despite being hooked up to different screens. The other...
The motherboard has a AM2+/AM3 socket, and the processor is AM2, while there is some compatibility between AM2+ and AM2 sockets, it is not guaranteed, so this could very likely be your issue.
Jul 23, 2011 | Biostar N68S NVIDIA MCP68S Socket AM2+/AM2...
How to turn on vga built in on motherboard biostar n68s+3
By default most motherboard with IGP (Integrated Graphic Processor) areconsidered as the primary graphics adapter unless you already configured the display to boot from PCI Express or PCI. in order to config using this setting follow the instructions below..
1. press DELETE during POST (Power On Self Test) 2. press RIGHT ARROW key to go CHIPSET Tab or Menu ENTER. 3. press DOWN ARROW key to go to SOUTHBRIDGE ENTER. 4. go to PRIMARY GRAPHICS ADAPTER select IGP--> PCI EXPRESS ENTER 5. press F10 Yes or agree ENTER.
The computer will automatically reboot.
Hopefully this information helped you Thank you for using FixYa..
Jul 18, 2011 | Computers & Internet
I lose my cd driver motherboard. no audio no sound in my pc. how to install without cd? how to download the audio driver?
You can download the motherboard drivers from Biostar support WEB site, please click on this link and select your model motherboard to download :-
http://www.biostar-usa.com/app/en-us/support/download.php
Sep 09, 2010 | Biostar U8668D (802700113338) Motherboard
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Barebones pc won't start
It is due to some wrong connection internal to mother board , try to remove each internal connector or external connector and try switch on the cpu
Dec 10, 2007 | Computers & Internet
Is there a power button cable connection adapter for IBM P4 motherboard to Biostar mother board?
if you mean that the power connector is a 3 pin socket connection and the pins on the motherboard are not in line and the middle connector hole is in the way, simply snip with scissors the end connector hole and seperate so you have a 2 pin and a 1 pin and just connect the 2 pin and use as a single connector because you wont need it and connect the 1 pin that you cut away to the other terminal
Jun 02, 2007 | Biostar P4M80-M4 Motherboard
Biostar N68S NVIDIA MCP68S Socket AM2+/AM2 micro-ATX Motherboard w/Sempron LE-1250 2.2GHz CPU, Heat ... (COMBO6S1250) Logo
199 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
