Question about Frigidaire Dryers
My stackable dryer will no longer spin...it makes a noise like it's trying but it will not budge...please advise. Thank you in advance for any assistance you can provide.
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 01, 2011
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
I have a stackable w/d 3/4hp. the dryer drum sounds as thou i have tennis shoes in it when it runs. please tell me what to look for.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 17, 2010 | Frigidaire Dryers
My DLG5988 IS MAKING A SQUEAKING NOISE AND THUMPING NOISE. I do have mechanical knowledge, but referring to "remove set screw" is pretty ambiguous without a schematic. I've removed a number of screws...
heatman101
wry2qwh
May 28, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Washer makes loud vibrating noise when spinning. GE stackable washer dryer
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion........
Jul 19, 2009 | Washing Machines
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
