Question about Norelco Health & Beauty
How do I change the battery on a 5801 XL shaver?
  • marcrubenste Apr 01, 2011
    There is only one screw on the back of the shaver, just above the power connector. I removed this screw but was unable to detach the back plate. I was afraid to try and force it. Any suggestions?
    I have experience with soldering.
  • 6,993 Answers
Most Norelco shaver models require soldering the battery pack in place. Keep this in mind before attempting to replace the battery. If you do not have experience disassembling electronics, you might take it to a professional for assistance.
Thing you will need to perform this task would be; a mall soldering pencil (3/2" 700 or 800 degree tip), screwdriver and electronic side cutters.
Carefully follow the steps below;
Purchase the replacement shaver battery pack that will accommodate the 5801 XL model. A number of models use the same battery pack and would follow the same instructions. The Norelco 5801 XL requires a 1.2V 600mAH battery pack with soldering tips. This battery pack has several applications besides the Norelco Shaver, allowing it to be found easily in your local electronics store or online.
Detach the back plate off the Norelco razor by using the screwdriver and removing the two screws that hold it together. This will expose the battery pack.
Locate the two spring clips that hold the battery pack in place. Push inward and then up to unlatch spring clips
Clip the old soldering tabs with electric side cutters to remove the old battery pack from the shaver. Do not attempt to salvage the old soldering tabs. Resoldering the old metal tabs might damage the PC board.
Bend the new battery pack leads into a "V" shape so they match up against the old leads of the PC board. Once aligned, push down on the battery to snap it into place.
Solder new leads to old leads with the soldering pencil.
Snap the two spring clips back into place and reattach the back panel.
Charge the new battery pack. Once completely charged, turn on the Norelco 5801 XL to test.
I hope the above instruction helps.......
Good luck.
Posted on Apr 01, 2011
  • Walesarumi
    Walesarumi Apr 01, 2011
    the back plate is clipped together so you have no choice than to apply some force, but not too much, in order to take it apart. You can use a small flat screw drive to pry it.
    Take care.
What replacement heads fit the 5801 XL?
Norelco HQ5 Replacement Heads
Philip norelco HQ5 replacement heads for men electric shaver norelco 5801xl blades replacement parts.
Apr 30, 2013 | Norelco Reflex 5801 XL Electric Shaver
How do you take the battery out?
You will find a helpful video at shaveroutlet.com. See link below for correct batteries and scroll down for videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Jun 23, 2011 | Norelco Reflex 5801 XL Electric Shaver
Need replacement head
Norelco Reflex 5801 XL electric shaver replacement heads is Norelco HQ5 shaving heads and you reviews HQ5 replacement heads for 5801xl heads.
Feb 27, 2011 | Norelco Reflex 5801 XL Electric Shaver
How long and how often do I charge Norlco5801XL shavor?
Model 5801XL requires 8 hours for a full charge. If the batteries are in good condition, it should have about a 40-45 minute run time
Feb 05, 2011 | Norelco Reflex 5801 XL Electric Shaver
I need rep;acement heads for my #5801 and am bewildered by the choices available. Need to know how much $ and where to order.
norelco 580xl replacement heads
philips norelco hq56 replacement heads for electric shaver philips norelco 5801xl blades. More detail at http://www.menelectricrazor.com/norelco-5801xl-replacement-heads/
Nov 24, 2010 | Norelco Reflex 5801 XL Electric Shaver
Where to buy replacement shaving head unit for norelco 5801xl?
www.shopping.com
www.bizrate.com
www.drugstore.com/...norelco_reflex.../replacement_heads_model_hq5.htm
Jul 09, 2010 | Norelco Reflex 5801 XL Electric Shaver
How do you change the batteries in the Norelco 5801 xl or can I get a manual for the shaver
Start by removing the two screws on the back and remove the back cover. You will then be able to see the batteries. They are soldered to the back side of the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries for model 5801XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to do this yourself, shaveroutlet.com can do it for you. See information link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Apr 29, 2010 | Norelco Reflex 5801 XL Electric Shaver
Health & Beauty Logo
63 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
