Question about GE Ovens
The element on the bottom of my GE oven had a glow in about a 1 inch section after I was baking and turned the oven off. It looked like it had a little sparks intermittently. Is it possible food on the element would cause this to happen? We shut off the electrical breaker and the glow went away immediately?? Do we need a new oven?
  • GE Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Apr 01, 2011
Changed my Oven element, now top and bottom don't heat up
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Feb 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
I have a GE JKP86-27 oven. Neither the bake or broil work. Microwave works fine. Controls come on for oven.
I, too, have the GE -JKP86. Microwave over oven. My oven would not heat up on bake or broil. Elements checked good, no fault codes. This is how I fixed mine: Shut off power at the box. Remove unit from cabinet. I placed mine on a chair. Remove cover(s) until you expose the circuit boards behind the control consol . The top board is behind the microwave controls, the bottom is behind the oven controls. Remove the bottom board by removing 4 screws. I take pictures with my smart phone, even some video. Helps me remember how everything goes back together. BE SURE THE POWER IS OFF, HIGH VOLTAGE IN HERE! One of the screws is hard to see. It is behind the ribbon connector. Unplug everything carefully. You will see a red and an orange wire north and south of a small relay. You must unclip the circuit boards from each other. Look for a missing drop of solder on the back side of the board with the relay. You will find it underneath where the red wire connects. Mine ( looking through a magnifying glass) looked like a crater with a wire sticking up out of it. It had overheated and the solder dripped out. The joint is inadequate. I cleaned and resoldered it with a nice blob. Reassemble and check. I just left mine on the chair. Power on. Select bake, 300, start. You should here the relays click and after about 45 seconds you'll see the bottom element glow. After one minute the relay clicks again ant you'll see the top element glow. They alternate during the preheat cycle. Put it all back together and shove it all back in the hole. Hope this helped!
Oct 11, 2012 | GE JKP86 Electric Double Oven
My GE Mod #JBP65GS1AD oven recently started acting up. The bake element had a small glowing area 1/4" long even with the oven turned off. We used it a few times, shutting off the power in between...
The way it can be tested is access the back panel so you can get to the oven control(its the clock asm) find a wire terminal on the clock marked as BA for bake and use a volt meter and see if 120 vac is coming from that terminal when the oven is off. The wire must be removed from that terminal so you not getting back feed and has isolated the test just to that. IF it has 120 vac or actually and voltage higher than about 5 vac when the oven is supposed to off the relay board (aka clock) is bad. UNPLUG OR TURN OFF BREAKER TILL WIRE IS OFF OF BA AND READY TO TEST then restore power make sure its marked as BA their is another marked BR thats for the broil element.
Good luck, i hope this helps
Gene
Aug 01, 2011 | GE Ovens
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
I have a ge medaillon 850 30'' range oven and the baking element does not comes red when I turn it on. There is only a small part on the left side of the element about 1 inch long that get red. All the...
Element is burned out. Get a replacement from GE or a repair/parts shop. They are relatively easy to replace, two wires and four screws or so. Be sure to unplug before you start :)
Dec 16, 2009 | GE Ovens
The baking element in the oven does not appear to be working
HI.I would test to confirm the actual issue. This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
Use This procedure below to confirm the failure.
With a multimeter, use these steps below to physically test for element functions.
1. Unplug the oven or turn off the power at the breaker or fuse box.
2.Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
4.Pull the element part way out to expose the oven's wiring connected the element.
5.Label the wires and secure them in place so they do not fall back into the cavity.
6.Disconnect the wires from the element.
7.Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
8.If the element tests okay, reconnect the wires, slip them back into the cavity and re-secure the element.
Oct 05, 2009 | Smeg Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Replacing Bake Element for JT980SK3SS (GE Trivection)
Thank you.
I found it without putting the 3 in the search.
All the screws appear to be 1/4 inch hex head screws.
Feb 25, 2009 | GE JRS06SKSS Electric Single Oven
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
189 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
