NI have just tried to setup my HP 3050 and stupidly put the black cartridge in the wrong way round. Now it wont come out. Is there any solution??
Errmm, ashamed to admit it, but I did the same thing... The plastic stoppers are the same width on both sides, so it should be possible to remove them. I think I'll just try to apply some lubricant with a cotton bud or a needle. There's bound to be some around the house. The plastic holder is not exactly solid either so I'm gonna try my luck bending it. I'll report back later if anyone else found a solution please please post it! Thanks!!
Posted on May 02, 2011
I have an HP Color LaserJet 3600n that was working just fine until I replaced the toner cartridges. Now the stupid door wont shut. All the cartridges appear be seated properly. Even tried putting the...
make sure that all cartridges are in correctly. Remove them and try too close the door again. On top where the transfer belt latches there is a lever which sometimes stays wrong way, needs to be reset.
Look up toner locks on line, check they are all ok. If they are broken, it is a fairly complex procedure to replace them
Oct 23, 2013 | HP LaserJet Office Equipment & Supplies
I bought an HP 3050 J610 printer less than a year ago, and need to replace the ink cartridges. Elsewhere on this site Upvarish advised someone else to use 61 cartridges, when the person asking for he
The HP 3050 Deskjet All-in-One takes the HP 61 cartridges: http://www.shopping.hp.com/product/CH376A%2523B1H . There are 2 cartridge boxes (black and tricolor: cyan, magenta and yellow). Both regular or extended use cartridges are available.
I hope this helps. If you actually have a Laserjet printer, please give the model of the printer to get the toner cartridge you need.
Feb 18, 2012 | HP LaserJet 3050 All-In-One Printer
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
What cartridge should i use for the HP Deskjet 3050 J610 I was told to get the 301 cartridge, but printer keeps rejecting it as the wrong one.
Hi
I am sorry but 301 is not the right cartridge.
The cartridge that this printer uses is Hp 61 Black and Hp 61 Tricolor
Regards
Upvansh
Dec 26, 2010 | HP LaserJet 3050 All-In-One Printer
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
Cartridges in the wrong way round and wont come out!
You can try and move the carriage (the part where the cartridges sit) manualy when the power is off but if it's to tight to move it then don't otherwise it can break.
Rather take it to an HP repair center.
Oct 30, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
14 people viewed this question
k24674
jasbo
jasbo
