Question about LG DLE2516 Electric Dryer
My dryer is not drying thoroughly - LG DLE2516 Electric Dryer
  • LG Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Apr 01, 2011
  • LG Master
  • 17,130 Answers
Please check the heaters and the motion of the drum , if there is less exposure of heat there will be low drying.
Kenwood condensor dryer is not drying thoroughly, whats wrong with it
Not enough information for long distance diagnostic
Dec 08, 2013 | Dryers
Hi, it seems the moister sensor is broken on my dryer. When it's set to autodry it just keeps drying for up to 24 hours.
You are correct, there's a problem with the moisture sensor if the dryer is heating but keeps drying when set to Auto-Dry. Either the sensor bars are shorted/touching each other or it is covered with thin film. Disconnect power then check the sensor bars for short circuit and clean thoroughly. Please indicate the exact model number of the dryer should you need further help.
Nov 11, 2010 | Maytag Atlantis MDG8400AW Gas Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Won't dry clothes thoroughly
It could be or the moister sensor is bad. Do this first for most people never think of doing this. Disconnect the entire venting duct work. Inspect it and clean it. If you get a wad of lint every foot length from this vent this will be your problem in drying clothes. The clogged vent will not let the exhaust pass through and the moister sensor detects that and shuts off the heat automaticly
Apr 20, 2010 | Whirlpool LER7646E Dryer
Dryer takes 2 or 3 cycles to get clothes dry. how
they make a dryer vent cleaning kit found at Home Depot and Lowes
Dec 16, 2009 | Dryers
Doesn't Dry Thoroughly
if you have not already you need to clean out your vent hose. if you have a bunch of lint build up in the hose or in the blower wheel of the dryer it won't move air through the dryer that needed to dry.
Jun 24, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
Dryer not drying after 70 minutes
your dryer could possibly have 2 heating elements and 1 has burned out, I had that problem once.
Apr 19, 2009 | Dryers
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Condenser dryer
doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Apr 09, 2007 | Zanussi TC180W Electric Portable Dryer
LG DLE2516 Electric Dryer Logo
420 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
