Question about Dishwashers
Not taking in water , manual says anti-flood device has activated
  • Dishwashers Master
  • 43,501 Answers
Hi, It could be that but it could be something more simple...
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Apr 01, 2011
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
F23
Unplug the appliance and take the rear cover off.
Check inside for water in the base activating the anti flood device.
Remove the water and try the machine again.
Hope this helps
Apr 23, 2011 | Washing Machines
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
Dishwasher turns on but nothng happens.
drain pump blocked and has overfilled flooding base pan and activating anti flood device tip machine to the left to remove water and consult handbook on how to clean pump outlet.
May 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool dihwasher adp 4552. Water comes into dishwasher, appears to start cycle then water is drained out again and light flashes to show a problem!
This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
Mar 25, 2010 | Dishwashers
Machine not starting ...Programme Progress Display light flashing
This normaly indicates an error code. Could be the anti flood device activated due to water leaks etc. The anti flood device (polystireene float and micro switch at base of machiene) puts the washer on pump out mode and shuts off the inlet water. Dry the water at the floor of the washer and check and rectify any leaks.
Jan 21, 2010 | Dishwashers
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Jan 18, 2010 | Dishwashers
Electrlux dishwasher - ESL 63010 - anti-flood
Got this tip from another board. Unplug and disconnect machine. Take machine out and tip 45 degrees to empty water in base of unit. Put everything back together. Thats it. Worked for me.
Dec 17, 2009 | Dishwashers
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Ariston ls2020 dishwasher dishwasher will not fill with water
anti flood device has been activated on inlet valve so appliance will not accept water
Jun 25, 2008 | Dishwashers
Dishwashers Logo
124 people viewed this question
Top Dishwashers Experts
