Question about HP Office Equipment & Supplies
I'm trying to print an envelope which way does it go into the printer?
I just went into the Publisher help site...thanks
Posted on Aug 07, 2008
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Envelopes won't print
Whichever application you are using for printing envelopes must have a set up icon and set, in options, for envelopes
That will show in which position your envelopes will be, when being transported through the printer. Like, print side up, right side of transport, and like that.
Make sure you haven't bypassed this, and be certain that the pass through matches what the printer expects when printing envelopes
My Word 2003, when using an InkJet printer, expects it on the right side, print up. When using my color LaserJet, expects to see the envelope in the center, print side down.
I hope this helps,
-a.
Jun 30, 2009 | Brother MFC-640CW All-In-One InkJet...
Won't print envelopes in black
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Apr 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
CANNOT PRINT ENVELOPES
i just wont be using the printer for printing envelopes. I have a problem with having to pay for support on any product.
Oct 03, 2008 | HP LaserJet 1220 Printer
Printing envelopes
You have to either use the MP Feeder or an Envelope Feeder. When you send the job to the "Manual Envelope" option, it will beep and prompt before each envelope is printed. Same will happen when you use the "Manual Paper" option.
You will have a hard time printing 1000 envelopes. The printer will print a rated engine speeed for the first 6-10...After that, the narrow media sensor will force the printer to slow down and you will proabably get 5-6 envelopes printed per minute.
Sep 18, 2008 | Lexmark T644 Laser Printer
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
