Question about Dishwashers
Hi we have a fisher and paykel DW60 dishwasher and the error code E5 keeps coming up. We have checked the water pressure and hose. The machine fills up with water but it won't go into the wash cycle and beeps displaying E5. Your help with this problem would be great. Thanks Frank and Kellie
SOURCE: dishwasher f1 problem on fisher paykel
先谢谢啦
Posted on Feb 21, 2008
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
SOURCE: error code. Fisher and Paykel Dishwasher
well since you asked on the 5th July, and no reply, doesnt look like you may get one. I thought thats what this site was about??
Posted on Sep 22, 2008
My fisher paykel dishwasher will not drain water it washes a while and when spray water it stops and e5 comes on screen leaving water in machine
See if the water hose to the unit is kinked or otherwise restricted. If the water hose seem ok them you might have a defective water inlet electro valve. The video may help, be patient e5 is explained Fisher and Paykel Dishwasher Error Codes
Dec 14, 2016 | Fisher Washing Machines
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
E5
Make sure the water inlet tap under sink is fully opened. The water pressure in mains could be lower than the setting on the dishwasher. Assuming it is DW60. See this manual.
http://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Mar 30, 2014 | Fisher and Paykel Dishwashers
Replace dishwasher drain hose F&P DW60
The attached assembly document might be helpful. To access the drain hose at the dishwasher end your best bet is to pull the dishwasher out from under kitchen cabinet and lay it on the floor on its side. Make sure you disconnect the mains power and the hose connections first. The hose should be accessible from the bottom of dishwasher.
http://www.jordansmanuals.com/ServiceManuals/FP/Dishwasher/DW60CDW2/DW60CDW2.pdf
Mar 25, 2014 | Fisher and Paykel Dishwashers
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
Our dishwasher displays F1 with a wrench???
check the water pressure is coming through first
Mar 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher&Paykel DW60 drain pump is blocked.
Check the drain hoses by removing the dishdrawers from the machine and pulling on the hoses. I installed a Fisher Paykel DD602 about a month ago and the bottom drawer was not draining. I removed the drawer and freed up the drain hose and the machine worked fine.
Feb 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does e5 mean on a dw60csx1
The DW60 manual shows the following possible meanings for the E5 fault code:
-Water tap not turned on.
-Insufficient water pressure
-Water supply hose is crimped or bent
-Drain hose is too low
For more info on fault codes, consult the manual. If you don't have one, here's a link http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Sep 09, 2008 | Dishwashers
Dishwashers Logo
744 people viewed this question
Top Dishwashers Experts
