Question about Bosch 11224VSRG 78in Bulldog SDS Rotary Hammer with FREE 412in Grinde
I need to remove the housing to repack the grease. I'm uncertain how to remove the chuck and selector switch do that the housing can be removed. Thanks
  • captlarrys Apr 01, 2011
    FixYa Expert provided Very Helpful Instructions! Thank you for your quick response. - Larry
  • 2,176 Answers
Unplug tool first, to remove the chuck first remove the dust shield and under that you will find a retaining/spring ring. Remove the ring and then the washers, push down on the last washer to release the steel ball that locks the bit into place. Then to remove the selector (make note of the position) push the button in and rotate clockwise to the hammer only position, using a small screwdriver FULLY depress the button and turn PAST the hammer only and you will feel it unlock. Gently lift the selector from the housing, look at the spring inside the gearcase because it will have to be in that position upon reassembly, Remove the 4 torx screws holding the gearcase to the motor housing.
Posted on Apr 01, 2011
How to fit front wheel bearings Which brand to use for quality
If the car is front wheel drive a puller is required to dismantle the hub a rather involved job better left to a mechanic .If rear wheel drive do the following. ( Applies to front wheel drive also.) Chock rear wheels,loosen front wheel nuts, jack up car, fit safety stands,remove wheel , remove grease cap from axle. remove split pin or locking nut on axle ,Remove hub, with a punch drive out the grease seal ,the tapered cone bearings can now be removed, the 2 bearing cups still in the housing will have to be pressed out ,all old grease has to be cleaned out. the new cones must be repacked with high temp bearing grease . tap in the seal with the lip facing inwards , slide on the hub fit the outer cone to the axle , the spacer and nut goes on next, tighten the nut to seat the bearings , spin the hub make sure its free to spin, back off the nut one eighth of a turn fit a new split pin or lock tab. fit grease cap and road wheel.
Jul 27, 2014 | Cars & Trucks
Can you repack the blade bearing on Vitamix Blenders?
On the Vitamix blender models we have here in NZ it is not possible to repack the bearings, you just purchase a new blade assembly complete with bearings and the driving clutch.
Nov 11, 2013 | Vitamix Super 5000 Work Top Blender
How do i replace the heat switch
find the round circular disk with 2 wires and white grease buried in the main transformer. should be on the outside of the coil r&r the thermal cut out switch.
the heat switch could also be the heat selector switch on the front panel remove knob remove wires from selector remove shaft nut reverse actions....
Feb 19, 2011 | Hobart Handler 140 Mig Welder
Is there wheelbearings in the rear wheels
go to autozone website and register your vehicle. look under do it yourself intermediate and look at the suspension...rear. probably has a hub assembly that has to be changed. i was just on site looking at one for an 04 grand prix. hope it helps you.
Nov 28, 2010 | 1993 Plymouth Voyager
Wheel bearings on 1988 chevy S-10
remove grease cap,brake caliper, then remove nut holding rotor now remove rotor, remove grease seal now both bearings should be out ,if replacing races then punch them out and tap new ones in, repack new bearings with grease install rear one and install new grease seal, slide rotor on slide frt bearing on, install washer and nut, tight a little to nearest cotterpin hole,put cotterpin in and put caliper on, hope this helps,good luck.
Oct 27, 2009 | 1988 Chevrolet S-10
Oil leaking from gear box on hammer drill
Where is the oil leaking from. By the chuck, or the selector knob, or is it leaking from where the gear housing meets the motor housing. I could be one of 3 things. There is a seal between the two housings that could be damaged, not likely though. There is an oring on the selector knob that can get worn, and there is a sealed bearing on the spindle that should not let any oil through. There should not be any oil in this tool for lubrication. Grease is used in this tool for lubrication. If you are getting oil or a liquidy type substance coming out it is more than likely the grease has broken down and needs to be replaced.
Oct 14, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I have a hilti TP800 that will not hammer. no polunging action for the chisels
TP800 are that takes me back. right hear we go...
as over people have sugested remove the 4 screws and the black plastic cap from the top of the machine. you should be able to see the con rod and the crank gear, and in front of the crank gear you should see the small gear which is the top of thr armature, you may have to scoop out some grease in order to see it. Check that the con rod is not broken. earlier machines had aluminium cod rods but the later models have plastic ones which were prone to breaking. this isn't to say that the aluminium ones never broke because they did and wow what a mess may made when they did. if your con rod looks ok, try this... keep your hands clear of the open gears, and put some glasses on. turn the machine on and make sure that the crank is turning. look at the small gear on the armature to see is it is wobbly. the small roller bearing at the top of the armature use to callapse causing them to wobble. this would strip both the gears. a good sign of this is metalic parlicles in the grease. this fault is very expensive as you will have to replace the armature, bearing, seal, and the crankshaft. ouch...BUT DONT DESPARE. if this looks ok, it must be the piston rings these are cheap, fairly easy to change and available, as they are still used on more current models. the part number for these piston rings (o-rings) is 13772. want to know how to change them?.. read on...The hardest part is removing the chuck as you must remove the retaining clip at the tip of the chuck. hilti make a special tool for this, but it is possible with a good set of circlip pliers, 2 flat screw drivers and 4 hands. top tip...Remove the rear handle assembly, just remove the 4 screws and pull it off, now the machine can be stood upright on a workbench. Wear safaty goggles and put a chisel in the chuck, this will help you not to loose the clip when it flies across the workshop, I hate it when that happens. once you have the clip off its easy from now on. and don't worry, there is an easy way to get it back on. ok, the clip is off. remove the washer and the plastic chuck cover. remove the circlip, remove the chuck sleeves, dont loose the 6 balls or the roller. now there is another large circlip which holds on the black plastic cover. remove them both. now you can see the 6 bolts which hold the machine together. remove them. remove the chuck.you will see a large o-ring around the cylinder, remove it. Now with a screw driver carfully split the cylinder at the point where the o-ring was sitting. carefully pull out the inner cylinder. dont loose the small plastic balls. if they fall out dont worry. put them to one side. inside this cylinder you will find the follower piston, just tap the clyinder on the workbench and it will fall out. replace the o-ring, smaer with grease and replace. The drive piston is probably still inside the red casing. Simply pull the con rod off the crank and tip it out of the casing. on early models this piston had 2 seals. 1 teflon ring over a green rubber O-Ring. on later models these were replaced with an o-ring, the same as the follower piston, the earier type may not be available in which case you may have to replace the pison as well in order to fit the newer o-ring system. once the seals have been replaced, smear with grease. place the piton inside the cylinder just far enough so the conector pin cant fall out of the drive piston. Replace the plastic balls into the detents in the cylinder. use grease to hold them in place. Replace the cylinder into the caseing but make sure that the cut out at the end of the cylider is facing down. This is where the armature gear sits. as you push the cylinder in ensure that the con rod is hooked onto the crankshaft. reassemble in reverse order. use grease to hold the chuck balls and roller in place. dont fit the rear handle yet..now for that clip that caused all the pain at the start of the job. PuT YOUR GOGGLES ON. stand the machine upright on the workbench and get somone to hold it. place the clip on top of the chuck body tube. get a block of wood and place it on top of the ring, and hit it with a hammer. this will knock the ring on 80% of the way, now tap it on with the hammer. refit the rear handle. your done,,,if you removed all the grease replace with a similar type. 70 grams (3 oz) in the crank case under that black plastic cover..
Well I hope that helps, its not as bad as it sounds.
good luck.
please leave feedback .
if you have any more questions please email me.
if you want a parts diagram i can email you a drawing of a TE804 which is virtually the same machine with a slightly different chuck.
paul@wysehire.gi
www.wysehire.gi
Oct 08, 2009 | Hammering
Struggling to remove chuck from makita 84444d
K what you need to do is remove the chuck retaining screw LH threads and then switch the gear selector to low and the clutch to drill only. Find a bent handle allen wrench about the chuck capacity and lock it in the jaws. put the chuck on a workbench or block of wood and on the long part of the wrench have it at about a 30 degree angle and strike it counter clockwise and that should remove it. you might have to hit it a couple times
Aug 20, 2009 | Makita 8444DWDE 18V 1/2" MXT Hammer Driver...
Changing a drill chuck
If this is a cordless drill open chuck jaws and remove the retaining screw (LH trheads), switch the clutch to drill only and shift gear selector to low. Insert a bent handle allen wrench about the same size as chuck (to keep from flexing) put chuck on workbench or block of wood and have the wrench about 30 degrees and strike the key counterclockwise to remove. You might have to hit a couple times but usually they will loosen up quickly. To install just reverse above. Let me know if I can help further.
Dave
Dec 25, 2008 | Makita Drills
Globe Meat Slicer Model # 500 motor runs blade not turning
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
Oct 30, 2008 | Berkel 827E Gravity Feed Deli Meat Slicer
Bosch 11224VSRG 78in Bulldog SDS Rotary Hammer with FREE 412in Grinde Logo
198 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
