Have switched from Vista to Windows 7 when my computer crashed. When typing the cursor moves up one or two lines and words are entered on that line instead of where I was typing. Very frustrating. This happens even when I am not using the mouse. How do I resolve it?
  • 961 Answers
Windows 7 has some capatability problems with software after the download. Try reinstalling your software or updating your driver.
Posted on Apr 01, 2011
  • 153 Answers
Repair Windows registry errors using PCFresher, this may resolve the problem.
Posted on Aug 05, 2011
How do you do multiple lines when embroidering words and get the space and the word to move down to the next line?
If I understand your question correctly, make sure that when you select multiple lines to copy and then paste that you select the entire lines. When you go to paste your multiple lines, make sure that your cursor is at the front of the line you want to move down. When you choose paste, the multiples lines will be inserted appropriately.
Example:
-->I have multiple lines here that I want to "embroider" into my document. I will click and drag my mouse from the beginning of these lines of text to the _very_ end of them. <---
and then choose copy (or cut).
This is the line of words that I want to move down to the next line.
^ I need to make sure my cursor is right in front of the "T" in This. I choose Paste and the multiple lines will be inserted above these words.
What application are you using? MS Word?
I hope this answer helps!
Sep 16, 2017 | The Computers & Internet
How to unlock keyboard?
press numlock button once
Mar 04, 2015 | Computers & Internet
How to use the basc funtion on the ti-83 is there a way that i can find out how to find the right way or a map to get to the box plot or make a historgram
Use the STAT utility to enter your data in a list. (STAT>EDIT. If you have repeated elements you can use L2 as a frequency list. Once you finish entering the data press [2nd][QUIT]
In the main calculator screen, press [2nd][Y=¨to enter the STAT PLOTS.
Press 4:PlotsOff to decativate all plots, then activate say Plot1.
1. Press 1:Plot1. Use arrow to highlight ON and press ENTER.
2. Use the DownArrow to move cursor to the line Type:
3. Select the plot type. (On this line only the right or left
arrows will allow you to select a type.)
Select the type and press ENTER.
4. Use DownArrow to move cursor to the XList line.
5. If the default (L1) suits your needs, press ENTER.
If not chage the list label to the correct one.
6. Do the same with the YList label.
7. Selectr the MARK style and press ENTER
6. Press GRAPH to have your plot
Sep 04, 2011 | Texas Instruments TI-83 Plus Calculator
A computer on my network has the same IP address; this causes a conflict.
This will cause one of the pc's not be able to get online. each one of ip's is unique. First this will need little knowledge if the ip's addresses are assigned manually. If not, rebooting the pc most times resolves the issue. If this does not work you need to open you command prompt which can be done by clicking on start and clicking on run on XP, clicking on start and typing cmd in to search in the bottom whith the little magnifing glass and it will pop up towards the top of that same window(it will say ether cmd.exe or command window. Once you see the cmd.exe do a right click on it and click run as administrator. this will work for vista or windows 7 any versions. once a black box opens just type in where cursor is blinking "ipconfig/release" and press enter. once you see the blinking cursor just type in "ipconfig/renew" and give it a minute to connect. When you type in this command do not type the " sign just words. ipconfig commands are same for windows xp, vista and windows 7. Hope this helps.
Nov 04, 2010 | Computers & Internet
My word processing software continues to move the cursor at the wrong time. When typing the cursor will move to the beginning of the previous word. I tried slowing the pointer speed problem still appears....
First uninstall world processing software then reinstall from disk. You can uninstall it from start menu->control panel->add remove programs you can also repair it from there. Also speedup the computer wit below method. Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check.
Let me know if you need further assistance. Thanks for using FixYa.
Aug 14, 2010 | Computers & Internet
Good Day' I have recently purchased a new Toshiba Satellite Laptop. The operating was Vista, so I changed it to Windows 7. Now whenever i'm typing the cursor just goes wherever it likes,...
Hi Barry,
You open up Google and search for touchfreeze. It fixes erratic cursor movements. Download and install it and your mouse pointer will stop moving as it wills.
Good luck!!!
Jul 22, 2010 | Computers & Internet
Keyboard cursor
Hello !
Sounds like you have Spyware or Malware.
Install and run software: http://www.spybot.com and http://www.malwarebytes.com
Hope this helps.
Oct 04, 2009 | ASUS Eee 4G Notebook
Cursor jumps around and typing can be almost impossible at times
seems to me an incompatible keyboard driver...
the best operating system till now (after linux) is windows XP
dont mess with vista or win 7 you will get many problems.
Sep 03, 2009 | Acer Aspire 7720-6844 Notebook
Letter writting problems
Do you use a laptop or some sort of keyboard with a mouse pad? My son used to have that problem when he would type as his thumb would accidentally hit the mouse pad and move the cursor. We solved it in a very low tech way by taping a notecard over the mouse pad when he was using the computer. Depending on the manufacurer, there are ways to turn off the mouse pad while continuing to use a mouse.
Dec 24, 2007 | Microsoft Digit Media Pro bx100005...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
