Question about Daewoo Heating & Cooling
Daewoo dbs-182lh starts and stops by itself. - Daewoo Heating & Cooling
    Brigadier General:
  • 4,736 Answers
If it's cooling to the temperature that you have it set for or the comfort level you have it set for, it's normal for it to cut off, once it reaches that temperature and holds it for 5 minutes. When the room temperature rises above the comfort level you have it set for, it turns back on. If this is what you are describing, it's functioning normally.
Posted on Apr 01, 2011
How to install a remote control to JVC TV?
  • Dear Sir:
    Please do the follow steps:
    Move the mode selector on the remote to "TV" and press and hold the television power button. Press "Enter."
  • 2
    Enter in the manufacturer's code for your television or other electronic device. The code is typically 2 digits long. The JVC manufacturer's code is "01." Other codes include "10" for Hitachi, "02" for Magnavox, "07" for Sony, "04" for Panasonic and "08" for Toshiba. Additional codes can be found in the user's manual for the JVC universal remote. Release the television power button.
  • 3
    Program a direct broadcast satellite (DBS) tuner by setting the mode to "VCR/DBS" and press "DBS." Press and hold the VCR/DBS power button and press "Enter". Press the buttons for the manufacturer's code, which are typically 2 digits. RCA is "19," Pioneer is "13," EchoStar is "21," GI Jerrold is "01" and Sony is "20." Additional codes can be found in the universal remote user's manual. Release the VCR/DBS power button.
  • 4
    Press the "Audio" power button to use features other than the television, such as a DVD player or stereo, and select the desired source. The options are DVD, FM/AM, VCR or DBS.
  • 5
    Set up the speaker settings by choosing "DVD" as the source. Hold the remote where you listen to the sound from the home entertainment unit. Press and hold "Smart Setup." Press "Enter" and move the cursor up and down on the television screen using the up and down arrows to select the distance between the front speakers and where you are positioned. Press "Start" and then "Enter.
    SINCERELY.GOD BLESS YOU
    ernesto cuadra
    managua, nicaraguaa c.a.
  • Feb 15, 2012 | One For All URC-3021 Remote Control
    Login DBS mBanking for the first time. Not able to proceed further after I get terms and conditions
    Please try this and complete.
    Once you get the Terms and Conditions page, Press the Menu button on your Phone and then Click Agree.
    This will resolve your problem.
    Sincerely Thiyaga
    Aug 30, 2011 | DBS Bank Ltd DBS mBanking
    JVC TH-C60 DBS stopped working
    When you say the "TV side" you really mean the Cable or Satellite Box audio, right? There's no digital optical connection intended for the physical TV.
    I hope you're not really looking directly into the cable with your naked eye. A safer way to visually check for the presence of red laser is to hold a thin piece of white paper up against the cable and observe the spot.
    With your remaining good eye, look INdirectly or hold a thin piece of white paper in front of the the optical port on the JVC to see if there is a visible red glow. Most likely the cable itself is the problem. Make sure it has large open loops rather than tight bends throughout its routing.
    Mar 24, 2010 | JVC TH-C60 System
    Daewoo lanos year 2000 se electric rad fan has stopped working.
    Find auto the temperature sensor , disconect the two wires and make a "jumper" between them, use a wire equal or with larger "diameter" (section) as the sensor wires itself. Turn the engine on. If you have already checked fuse and relay and you 100% sure they're ok the fan must start spinning...be carefull with the fan blades. If not, you may disconnect the fan wires and supply energy straight from the battery. Be carefull again some sparks may come out and try not to short circuit the wires that may create another electrical/electronic problem, okay? Hope this can help...vmossmann from Brazil
    Oct 21, 2009 | 2000 Daewoo Lanos
    Oil light is blinking on 2001 daewoo nubira only when at a stop.
    Hi. there could be three issues here. One could be that you need to change the oil in the engine. Secondly, the oil pump itself may be malfunctioning. Also, the oil sending unit(module) may be malfunctioning as well. A good starting point would be to check the oil to see if its low or needs changing.
    please rate and god bless.
    Mar 18, 2009 | 2001 Daewoo Nubira
    Setting the component video settings
    If I tell you how I fixed it, send me $9.99.
    Dec 17, 2008 | JVC RX-8040B Receiver
    About visual basic coding
    The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
    Hope this helps! Please let me know if you have any questions.Thank You,Raph30
    Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
    I have a Denon AVR-3300. I am getting picture but no sound in the TV/DBS mode. Every other connection is working fine.
    Try switching one of the working source connections to the TV/DBS connection. Also note that TV and DBS are actually separate inputs on some models.
    Apr 05, 2008 | Televison & Video
    Heating & Cooling Logo
    93 people viewed this question
    Top Daewoo Heating & Cooling Experts
    Tim Whalen
    Craig Hill
    Dan Webster
    Dan Webster
    Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
