Question about Safe International Locks & Locksmithing
I have a yale electronic safe, i cant find the emergency key and the batteries have died. How would i be able to open the safe?
3 Suggested Answers
SOURCE: BATTERIES FLAT CANNOT OPEN MICROMARK SAFE WITH KEY
http://www.rotteneggs.com/r3/show/se/198433.html
:D x
Posted on Jun 02, 2009
  • 40 Answers
SOURCE: I have misplaced my emergency
Yes, a locksmith should open it up, however, check with safe maker first for a solution, then you can ask a locksmith
Posted on Dec 16, 2010
My Safemark Systems electronic safe won't open. I have the code but my batteries are completely drained. How do I get in safe?
4 0 Electronic Safe
use your cobra key or buy this Emergency Handheld Override,that goes to it,or replace the batteries.
Emergency Handheld Override EHO
Safemark Systems
2101 Park Center Drive
Suite 125
Orlando, Florida 32835
USA
1-800-255-8818 USA
1-407-299-0044 International
1-407-299-7650 Fax
1-800-299-4288 Tech Support
May 01, 2015 | Locks & Locksmithing
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
How do I open my Yale Home Safe YSS0000NFP. The batteries have gone totally flat.
Yale battery operated safes have a manual override function for which keys are supplied.
Nov 14, 2014 | Locks & Locksmithing
I need to open the safe and the batteries are dead
Hello there,
You SHOULD have a mechanical key to open it in case of emergencies like this..
If you purchased it, you will have the key friend.
Extract from this page.http://www.officespecialties.com/fireking_lt1507_personal_laptop_safe_182604_prd1.htm
'The electronic lock provides security and easy access and it is equipped with a mechanical key for emergency access. The door is 9 Gage and the body is 14 Gage steel to resist break-ins.'
If it is lost, you need a locksmith.
Sep 24, 2014 | Safe International Gary LT1507: Laptop...
I need a replacement key EX2005138875 for my Safewell electronic safe. The batteries have failed and I cannot open the door.
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Mar 15, 2011 | Locks & Locksmithing
I cannot open my Noble safe with the code I had. It seems that my code is gone and I don't find the key to open the safe. What can I do ? songa
I cannot open my Noble safe. I havent used it for 1 year, it has no battery and cant open it with my key. I cant remember the code, but i wont be able ti use it with no batteries.
What can i do
Feb 23, 2011 | Safe International Digital Electronic Safe...
Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
May 09, 2010 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
718 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
