Question about Bosch Drills
Cant get the bit out of my cordless bosch drill, chuck seem to be jamed and wont open
  • 2,176 Answers
What you can try is to spray penetrating fluid on the chuck collar, jaws. Next if you have a GOOD pair of gloves hold the collar and then using the drill motor try and loosen the chuck. If you have a vise with a pair of soft jaws without clamping too tight you can try the same thing. The main purpose is to let the drill torque loosen the chuck collar to release the bit.
Posted on Apr 01, 2011
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Broken drill bit stuck inside drill
if you open chuck all the way the drill bit should just fall out
Dec 11, 2013 | Bosch 13624 24V Cordless Hammer Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Drill chuck stok in the thigt possition cant get the bit out ; cant make de chuck to open or close
Sometimes this happens when you have a drill bit that slip. Take a pair of channel lock pliers, and try and turn the chuck counter clockwise. Do it sharply so the drill doesn't turn. IF that still doesn't work put the drill in reverse and try the channel locks again
Jul 05, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drills Logo
395 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
