Question about Tomtom GO 930 GPS Receiver
My computer does not recognise my home dock - Tomtom GO 930 GPS Receiver
    Problem Solver:
  • 12 Answers
This issue might occur due to the USB port, USB cable being faulty or the settings on the device are corrupted.
To resolve the issue, you can try switching to another USB port on the computer. It can be either the back or front of the computer.
Then perform a soft reset on the device while the device is still connected to the computer. This will force the computer to recheck the device connected to the computer.
There must be a soft reset switch at the bottom of the device. You need to press it with a ball pen tip or any other pointed material for 20 secs.
If the issue still persists then make sure you have not disabled the USB adapter in the device manager. You will need to renable it from there.
If the issue still persists then it could be possible that the dock itself is faulty. You can try using a different USB cable like that of a digital camera and check if it works with the GO 930 device.
In addition, to isolate the issue, you can also check if the device works on any other computer
Posted on Apr 01, 2011
I phone will not charge
Things to check:
There could be lint in the dock connector. Look in the bottom of your phone and see if there is any lint blocking the dock pins.
Check the dock pins to make sure none of them are damaged or missing.
Check the cable you are using on another device and make sure the cable works.
Plug your phone into the cable and a computer and see if the computer recognises it.
Aug 27, 2013 | Apple iPhone Cell Phones
IPhone not recognised when docked
Try a different charging dock make sure it puts out the same volts as the iphone has
Oct 03, 2017 | Philips Audio Players & Recorders
How do I update my GPS system?
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. You choose the ones you want to install.
Please, report back if you need further assistance
My ID: alexocuello_
Mar 29, 2010 | Tomtom GO 700 GPS Receiver
How do i update my tomtom?
3) Plug in the GPS2_bing.gif dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
My ID: alexocuello_
Mar 25, 2010 | Tomtom ONE XL GPS
Trying to do a map update. but my computer will not recognise the gps, do i need to download a driver for go 720 ??
I had this issue with my Go930 and solved it for Tomtom!! Firstly, you need to ensure that you have the most up to date version of Tomtom Home, from here (http://www.tomtom.com/services) and then before you dock your 720, put an SD card in. It doesnt have to have anything on it and you should only only have to do this the first time. Tomtom home will then ask you which device you wish to update, internal HDD or external. Choose the internal HDD and you are sorted
Feb 19, 2010 | Tomtom GO 720 GPS Receiver
Home dock is connected to usb port of computer
try downloading the newest version of the software from TOMTOM's website. Download and install it first allowing it to put the necessary drivers on the computer. the software will prompt you to connect the gps after the drivers have been loaded.
Hope that helps
Jan 03, 2010 | Tomtom GO GPS Receiver
MP3 player stuck on DOCKED mode
No, just remove battery then reinsert while holding switch to left. Player will reboot into recovery mode. Select Cleanup (YES) and it will do its stuff then select "REBOOT" and it will start up in normal mode.
Aug 06, 2009 | Creative Labs Zen Micro MP3 Player
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Foxconn 845GV4MR-ES Lan refuses to work
Have you installed the correct drivers for this mobo? You can get them here:
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=845GV4MR-ES&TypeID=en-us0000004
I've used these with XP Pro and everything works. You have to install the chipset driver before the others. Also, do you have the onboard network adapter enabled in the BIOS?
Jun 22, 2008 | Foxconn 845GV4MR-ES Motherboard
Tomtom 510 not recognised by Tomtom Home
HI STAMOS CAN NOT GIVE YOU A SALUTION, BUT I AM HAVING THE EXACT SAME PROBLEM.I AM RUNNING WINDOWS XP HOME AND I HAVE PUT MY TOMTOM510 INTO COMPUTER 3OR4 TIMES WITH NO PROBS NOW ALL OF A SUDDEN IT SAYS IT DOES NOT RECOGNISE IT.THOUGHT MY HOME DOCK WAS FAULTY BUT WHEN I PUT MY CARD READER IN IT SAID THE SAME THING,SO I THINK THE PROBLEM IS THE COMPUTER.HOPE YOU MANAGE TO SORT IT.IF I SORT ANYTHING WILL LET YOU KNOW BEZ511
Apr 02, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 930 GPS Receiver Logo
125 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
