Question about Garden
Battery dead, need another one - Garden
  • 17,130 Answers
All what is required is to get a same type and size to fit the compartment.
Now the most important factor is the VOLTAGE AND CURRENT FACTOR.
the voltage must be the same but the current for the same shell size can be a fraction more and will only be helpful.
Posted on Apr 01, 2011
My key fob is lost and I need to get into a avalon
You'll need the door key with a dead battery because the key fob won't unlock the doors with a dead battery lost or not.. Toyota dealer is the only place a new key fob can be purchased that will work.
Oct 01, 2014 | 2009 Toyota Avalon
How to use a compact jump start system
The Jump Start replaces another vehicle when jump starting. Make sure unit is fully charged. If you need a jump start because of a dead battery in your car, connect Red lead to + battery post on your dead battery and Black lead form jump start to - battery post on dead battery. Turn unit on and start vehicle.
Sep 01, 2014 | Power Center Jumpstart 11-411
Can a dead battery be recharged and how
If you have a capable battery charger, then a dead battery can be recharged. I would suggest recharging the battery to the proper voltage and then letting it set for 24 hours. In 24 hours check the battery for the correct voltage. If it maintains the charge, then you should be okay to reinstall the battery. If it does not, then you may have a dead cell in the battery and it would need to be replaced. Video about How to Test Battery
Aug 28, 2014 | Exercise & Fitness
Intermittently dead battery
I had the same problem on my jeep, clean and tighten the battery posts an d terminals. I did the that and it stopped.
May 02, 2012 | Cars & Trucks
My acer notebook wont charge all the way it stops at 87% and it wont charge anymore.
hello
The battery is starting to be dead. one or couple of battery cells gone dead, need replacement. if the battery is giving enough backup time then no need to replace it immediately. let the battery gone dead, sooner or latter, then you can replace or repair it,
good luck
Dec 14, 2010 | Computers & Internet
My psp can't turn on with the battery but when i put it on the charge it work .what can i do ?
That problem means your battery is dead, and needs to be replace!
Check the physical and voltage output of your battery, if its bloated, that means battery is dead. If no power output from battery and its not bloated, the internal circuit in the battery is dead.
Hope that explains everything!
Thanks for using Fixya!
Dec 09, 2010 | Sony PlayStation Portable (PSP) Console
Battery goes dead over night
First thing to do is find out if it's the battery or the mower. Disconnect the battery and leave it overnight. If it's dead in the morning, you need a new battery. If not, you either have a charging problem (not likely if the battery isn't dead after using the mower) or you have a current drain.
Oct 22, 2010 | Toro 42'' Zero Turn Lawn Mower Trailer...
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
Will not turn on or charge. Will not power on when hit on/off switch. Will not charge (no blinking light) when plugged in.
Sorry, but this indicates very strongly that your battery is completely dead. To confirm this simply wipe the terminal of your battery very well and hold the terminals of the battery to your tongue. If battery is working, you should fill a sensation in your tongue at the instance of contact, otherwise you just got the confirmation you need that your battery is dead. I mean dead, not low, but dead. Change the battery.
Sep 13, 2009 | Kodak EasyShare M380 Digital Camera
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
