Vehicle will click but not start, tried juming still clicks , only 10000 original milesany suggestions
Assuming your battery is properly charged and has a good connection, it's your starter solenoid (relay) that has failed.
The starter solenoid receives a large electric current from the car battery and a small electric current from the ignition switch. When the ignition switch is turned on, a small electric current is sent to the starter solenoid. This causes the starter solenoid to close a pair of heavy contacts, thus relaying a large electric current to the starter motor, which in turn sets the engine in motion.
If a starter solenoid receives insufficient power from the battery, it will fail to start the motor, and may produce a rapid clicking or clacking sound. The lack of power can be caused by a low or dead battery, by corroded or loose connections in the battery cable, or by a damaged positive (red) cable from the battery. Any of these problems will result in some, but not enough, power being sent to the solenoid, which means that the solenoid will simply make a clicking sound, rather than setting the starter motor in motion.
If these items are all okay, it is likely you need to replace the solenoid.
