Question about Acer Computers & Internet
"Ethernet controller does not have a drive" - how
  • Acer Master
  • 3,606 Answers
Hello you can download the driver here at acer:
http://us.acer.com/ac/en/US/content/drivers
By selecting:
Desktop or notebook.
The 4 digit number of the pc.
And confirm your selection.
Next you have to select your windows system 32 or 64 bit.
Download the lan driver (or chipset driver depending on the model)
And unzip the file before you install.
Good luck
Posted on Dec 17, 2012
  • 368 Answers
Glad to HELP YOU!
All you have to do is to download and to install your driver.
You can find it on the manufacturer's web page (Acer) HERE.
Or, you can download and install Driver Magician Lite from HERE; once installed it will detect and it will indicate the right driver(s) that you might need.
GOOD LUCK!
Posted on Apr 01, 2011
My Toshiba L640 model encountering this problem. the time i open my computer the Toshiba logo appears and the F2 to utility system and F12 for the boot if you will allow the computer to proceed without...
That means the hard drive has failed. You'll likely need a new hard drive. Go into the utility system using F2 and see if it still sees the hard drive. If it does, and you don't hear something going "click, click, click" or "kchunk, kchunk, kchunk", there's hope. If you don't hear those noises, and can borrow a Windows disk to boot from, you might be able to correct the issue running the check disk utility.
I would recommend you turn it over to someone that really knows what they're doing.
Jul 05, 2011 | Computers & Internet
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
When reinstalling windows xp, I had to activate windows. Well I am now not connected to the internet.It seems I am missing "ethernet controller","multimedia audio controller","sm...
You can download the missing drivers from here:
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=11&familyind=121125&machineind=121227&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=9&doccategoryind=0&operatingsystemind=121210&validate=true
Here are specific links for what you need:
Audio:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q2aud02us13.exe
Ethernet:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q38z01us.exe
Video:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/e7az65us.exe
or
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/e49z86usa.exe
USB:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_drivers/q1chp01us13.exe
Good luck with it, drivers are usually the biggest pain after a fresh install.
Moshe
Jan 31, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Hi.. i reformatted one of my pc with intel pentium d and mobo "msi pm8m3-v"... the problem is, i lost the driver cd... so i searched the internet and found drivers.. vga, raid, audio and stuffs.....
Keep doing what youre doing and put it on the USB drive its the only way really. If a driver is not an EXE file you need to go into device manager right click on the unknown device and click update driver. Choose the option to let you choose not automatic and browse to the folder your driver is then install it. cheers from Scott and plz vote
Nov 02, 2010 | Computers & Internet
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Ethernet Controller
I had to reinstall XP like 6 months ago, on a dimensions 3000. just reinstall the drivers. here i think this is all of the drivers.
just start "Dell Driver Reset Tool.EXE"
and run "Sownd driver for 3000.EXE"
driver for vga "Intel(R) 82865G Graphics Controller.exe"
and the Ethernet driver "Intel PRO100 VE Network Connection.exe"
Click Here for a zip of all the drivers.
Feb 05, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
