Question about Poulan 14" Chainsaw
HAVE A 14 POULAN LAND SHARK. WONT START? INSTALLED NEW PLUG, ,GAS, BAR AND CHAIN, CLEAND AIR FILTER . NO LUCK.
  • 784 Answers
Hawe you checked idle settings?
Posted on Apr 01, 2011
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Just replaced carb new spark plug and new gas line. Will start and run for 2 minutes . When you press the throttle it dies and won't start again. Same problem I had before replacing carb.
Rick if you are sure it is fuel related issue, does sound like it may be running out of fuel. Check the fuel filter in the gas tank and replace, also check the fuel tank cap as the vent in it may be plugged,which will cause this issue.
A similar issue to this, is when the muffler screen gets plugged with carbon on some models. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Replace Chainsaw Fuel Filter
What to do if your chainsaw wont stay running
Symptoms Repair Of Clogged Spark Arrester On Grass Trimmer
Chainsaw Repair Help
Apr 14, 2016 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
New spark plug plus new air and fuel filter. Chainsaw will not start or even fire.
If there is a good spark and fuel getting to the plug there are only two reasons why it will not fire, sheared flywheel key knocking the timing out, or it has partly seized and has low compression.
Aug 09, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
It strats wount idel or reve up it ran fine till got dirt in the carb it got cleand and now this
sounds like you still have a dirty carb but.I'd change the plug. clean the air filter. check the fuel screen in the fuel tank, make sure it is fresh fuel, if none of this works I would think your carb is still dirty or out of adjustment.
Feb 23, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How do you get to the air filer
a Poulan PP3314 IPL example follows:
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008_530165457.pdf
Page 2 displays the engine cover, the 3 screws that hold it fst and the air filter cover, All must be removed starting with the engine cover.
You can download a manual and parts list for your saw here:
CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided). Good Luck, HTH
Lou
Feb 27, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
The chain has come off of my 14'' poulan gas chainsaw and I can't get it back on?
Release chain tension. Loosen nut on bar, re-install chain, check for chain not binding when moved by hand, but snug on bar, tighten and you should be back in business.
Aug 28, 2009 | Poulan Garden
Saw does not idle and is hard to start. It is a P3314 Poulan
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Jun 24, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 14" Chainsaw Logo
132 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
