Question about NEC Versa 6060 Notebook
I don't know how i m getting the blue printed characters on the keyboard keys i.e 456 instead of uio unless i press down the Fn key. how do i get the main characters again?
    President:
  • 1,623 Answers
You will need to press the numlock key on your keyboard this will then allow you to use the keys normally
Posted on Apr 01, 2011
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
Tip
Why is my Laptop keyboard typing the wrong characters is it a bug ?
Sometimes its just down to the Regional settings not set up correctly so the " and the @ are reversed with US and UK keyboards.
However,
Laptops have the in built functionality of using a number pad when the NUMLOCK key has been pressed, there may not be a light to show this !!!!
The following keys will be designated as follows until the NUM LOCK is pressed again.
789------------ >789
UIO------------ >456
JKL ------------ >123
M--------------- >0
Don't get caught out my Father in Law was willing to pay PC World £25 to sort this out until he gave me a call!!!!
on Jan 08, 2010 | Microsoft Windows XP Professional for PC
Unless i hold down the Fn button, when i press uio i get 456
Sounds like you have the Number lock key enabled, try disabling it by pressing the Num Lk button on the keyboard. Hope this helps, best of luck.
Feb 02, 2011 | Computers & Internet
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
How to use keys
There is a BLUE-coloured 'FN' key on the bottom-left of the keyboard. Hold that key down, and then press one of the "blue" keys, to get the "alternate" meaning of that key.
Apr 05, 2010 | Adesso ACK-595 Keyboard
Restore my acer 3680 back to factor
to restore your system to factory default....restart the system..immediately hold the AltGr key(the one right to the space bar)down...and keep tapping the F10 key...you should screen that says windows is loading file..if not try a couple of times...once you get that screen...navigate through the screen ..this will help you restore system to factory default
let me know if this helps...
regards
Dec 29, 2009 | Acer Aspire 3680 Laptop
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Oct 06, 2009 | ASUS 90-A4C1K1000 Keyboard
When typing along the keyboard qwertyuiop, the keys that have numbers will type numbers instead of letters,uio will type 456. If you hold the FN key in it will then type type letters, how do I correct this...
This means that NUM LOCK is set to on. All you have to do is to press the Fn key and then locate the NumLock key and press it. The num lock is usually also highlighted with the same color as the Fn key.
Please comment back if you still have issues. I will be glad to assist you further.
Aug 06, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Blue characters on the keyboard when I type
It is a combination of key known as "Function" (Fn, for short). You have to press it and hold while pressing other keys showing the blue letters on it. The most common use is to make a virtual Numerical Keypad on laptops, so you can perform calculations. To be back to normal mode, you need to press FN+F8 (or the key with the Calculator icon).
May 28, 2009 | Compaq Presario R3000 Notebook
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
NEC Versa 6060 Notebook Logo
374 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
