Question about Cameras
I OWN A ROLLEI 35 RF (range finder) manual 35 MM Camera. What size battery is required for the light meter.
  • 977 Answers
Hi!
The original battery is no longer available... Instead, you'll need to use a MR-9 adapter with a v386 battery.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Posted on Apr 01, 2011
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Oct 17, 2017 | Pentax Cameras
I cannot retract the lens back to my Rollei 35 se
Your question seems to be mis-categorized under slide projectors, if you are asking about Rollei 35 SE camera, the lens will only retract if you cock the shutter with the wind lever, then press the button next to the shutter release and rotate the lens a few degrees.
Nov 13, 2013 | Rollei 66 Dual Slide Projector
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Rollei 6008I problem
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
HTH
Mar 30, 2017 | Rollei 80mm f/2 Xenotar PQ Lens
Insructions for piranah fish finder at home,
Go to this webpage and click on the link of the manual of you finder and it will open up your manual.
http://www.humminbird.com/support/FAQ.aspx?faqid=72
Dec 29, 2008 | Humminbird Smartcast Rf 35 Dual Display...
Need Manual
Display Optical Viewfinder Yes Optical VF Type Optical LCD Viewfinder Yes LCD Size (inches) 1.5 Power Battery Form Factor 2 x AA or 1 x CR-V3 Usable Battery Types Alk. / Lithium disposable, NiMH rechargeable Batteries Included 2 x AA Alkaline disposable Battery Charger Included No Flash Internal Flash Yes No of Flash Modes 4 Flash Modes Automatic, Fill (On), Off, Red-eye reduction Flash Range Description Unknown Ext Flash No Connectivity Video Out Yes Video Mode Switchable Yes External Connections USB 1.1 Other Connection DC In Included Software Unknown OS Compatibility Windows, MacOS Image Storage Usable Memory Types SD/MMC Other Memory Types Built In (8MB) Memory Included (MB) 8.0 Uncompressed Format None CCD Raw Format No Compressed Format JPEG (EXIF 2.1) Movie File Format MotionJPEG (AVI) Image Capture Image Resolution 1280x1024, 640x480 Movie Resolution 320x240 Aspect Ratio 4:3 CCD Sensor (Megapixels) 1.30 CCD Manufacturer Unknown CMOS Movie Audio No Quality Levels 3 Lens Digital Zoom Yes Digital Zoom Values 2x Auto Focus No Manual Focus No Normal Focus Range 120 cm to Infinity
49.0 in to Infinity Max Aperture f/3.0 Aperture Range Description f/3.0 Lens Thread Type None Exposure Number of White Balance Settings 5 White Balance Settings Auto, Sun, Shade, Fluorescent, Tungsten Manual White Balance No Longest Shutter Time 1/20 Shortest Shutter Time 1/2500 Exp Adj Range 1.5 EV Exp Adj Step Size 0.30 EV Metering Modes Auto Spot Metering No Aperture Priority No Shutter Priority No Full Manual Exposure No Self Timer 10 seconds General Model Number 3315 Camera Format Compact Currently Manufactured No Retail Price $99.00 Street Price $105.00 Price Update Date 2003-10-07 Date Available 2002-07-22 Remote Control No Tripod Mount Material Unknown Operating System Windows, MacOS Weight 120 g
4.2 oz Weight With Batteries? No Size 108 x 59 x 36 mm
4.3 x 2.3 x 1.4 in Warranty in Months 12
Oct 26, 2008 | Vivitar ViviCam 35 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
