Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Pck up Water will dispence put will not pick up
    President:
  • 1,673 Answers
Makw sure the recovery tank lid is secured down all of the way around, sometimes it doesn't catch and will **** up. Also check the filter on th inside of the recovery tank lid, it needs to be at least a 1/4 in. gap from the top. If it is pushed up all of the way, then it won't allow suction.
Posted on Aug 10, 2008
My shampooed won't pick up ythe water
does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
Jul 01, 2017 | Vacuums
Cleaned machine filled with water pushed botton but water will not come out
Hey Parker! I know how frustrating no spray can be.
Here is a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
Water will not dispence while cleanning
Before using tool
It may be necessary to remove air from
the system ("prime the pump") so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning
.http://hoover.com/file/604/
Sep 18, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Bissel Turbo pro will not release water.
empty machine out,put 1cup of CLR and let it set 24hrs. then try dispencing or spraying machine,hard water deposets may be bloking the jets.
Jul 31, 2010 | Bissell Vacuums
My bissle steam cleander # 8920 wont dispence and water or solution.
mine was plugged up in the heater which is inside the handle. i took in off and blew through it, ( watch out for water coming out, it hit me in the eye, haha for my wife) now it works fine
Jun 09, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
It won't dispence any fluid
make sure the tank is properly seated.on the tank there should be a filter or a tube make sure they are not clogged
Apr 07, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Hoover shapmpooer will not dispence the water
Check for clogs in valve (under the sponge on the water tank.
Make sure the sponge is clean
See if the screen is not clogged.
See if the supply tube (white straw inside water tank is not clogged)
Feb 17, 2009 | Kirby G4 Bagged Upright Vacuum
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
The water swirts ou put the vacuum does not pick up the water
Make sure that you are using the wet hose and that it's not clog and hooked up tight to the hole in the front of the vacuum.The same place that you would hook it up to vacuum.
Dec 02, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
