Question about JVC GRD72 MiniDV Digital Camcorder
Can't download video on Windows Vista
I can't capture video from my GRD72 with my new computer - I emailed JVC and they said to use a DV or Firewire cable and capture into Windows Movie Maker. I bought a 4 pin to 4 pin cable but my computer still doesn't recognize my camera.
  • alaskabound Feb 10, 2009
    I plug into my laptop that uses Vista and it does not even show it in a windows explorer screan as being pluged in. I m pulling what little hair i have left out.
    Master:
  • 763 Answers
Try to use windows xp instead of vista. it seems that your driver and your os vista are not compatible. hope that helps!
CHARCOIS
Posted on Aug 05, 2008
How do i get moving images from my GR-D290 to my PC? I can watch them on my camcorder but would like to get them loaded to my PC so that I put them on a DVD. And so that I can record new events
Use Firewire cable connected to firewire port of Your computer. Even Windows movie maker can capture images from any DV camcorder. After capture it´s easy to burn DVD with any burning software. For more questions email me.
Sep 05, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I HAVE JVC GR-DX307 AS - how to save the video on my laptop or how to save it on dvd
To save the video on a computer, a firewire connections must first be established from the JVC GR-DX307 AS to the appropriate firewire port of the laptop (assuming it has one or through a PCMCIA firewire adapter card if required). In the camera, the FireWire/DV port is located beneath the mode dial on the left side of the JVC GR-DX307’s body. To access the FireWire/DV port, the LCD monitor must be first opened.
Soon as that connection is established, you can use Windows Import Video (Vista) to capture / download the videos.
Alternately, the A / V port of the camera maybe used to connect to a DVD Recorder for direct, realtime copying & burning. For the disc to be playable in another machine, it must be finalized.
Good luck and thank yu for using FixYa.
Jun 24, 2009 | JVC GR-D370 Mini DV Digital Camcorder
I have a JVC mini DV and want to down load to my computer but don"t know how its a
First of all, you need three things to do this.
1. A fire wire port (or card which has the port and is installed to a pci slot in your computer).
2. A firewire cable which connects your camcorder to your computer.
3. Software or application for "capturing video" <--(not download video). Video editing software all consist of this application and is what you really want to acquire since it also allows you to edit you video.
Windows movie maker is a free download you can get it here.
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=windows+movie+maker
This page allows you different options depending on your type of operating system. Be sure to choose the correct download to avoid conflicts. ie: windows xp, windows vista, and there is even a windows live download.
Once you download and install the software, plug in your device using your firewire cable and port, select "capture video using windows movie maker", then follow the directions or use help. Windows movei maker also has decent editing options considering it is free software.
Good Luck!
Jun 06, 2009 | JVC Video Cameras
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
cheers,
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
JVC camera software GR-D70 for windows vista
Like most I have searched the web for drivers, preferably free ones. I emailed JVC Australia who responded with tis solution.
The camera has a connection called DV. The DV connection is used with a cable called Firewire.
Firewire is a driver less cable and will allow you to stream you video footage across from the camera to your PC.
USB is used for data transfer and need drivers, you would use this mainly to transfer still images or data files off a HDD camera.
If you use firewire and the DV connection you will stream the footage across to the PC and the PC will capture the footage as it is playing.
The firewire is about $15 and can be purchase from stores such as **** Smith, Bing Lee, Harvey Normans and Tandy. I would suggest that you take a photo of the connections on your PC as there are two types of DV connections. (4pin - 6pin)
Feb 12, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
1394 Fire Wire
I change my PC to new windows vista and the new PC don't recognize any VCR throw firewire, but the machine recognize my canon LG-2 by firewire. I need something special like a special driver to run my JVC's BR-DV3000 & BR-HD50 for capture video
in vegas pro 8.0?
Feb 11, 2008 | JVC BR-DV3000U DV/Mini DV VCR
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
Jan 20, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Capturing D-VHS thru firewire (1394)
Here's what you will end up doing. ANALOG CAPTURE. I could help if we knew more about the HOST PC/MACINTOSH machine. It's only my opinion that to get a FIREWIRE ANALOG VIDEO DIGITIZER is not a great idea.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Video Cameras Logo
100 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
