Question about Lexmark C534dn Laser Printer
Error insert tray, the printer don't see the tray, I think the sensor tray is broken. How can I change it? And how can I order it (someone know the part number?)
  • Maurizio Sorgo Apr 01, 2011
    Thank you, but there's nothing in that page! It's a blank page with written "Printer Solution" and nothing else.
Konica Minolta Magicolor 4690MF I have a caution error tray2 open close tray2 can someone help close tray2
Check the sensor for tray #2. Another remove the tray #2 check for broken acturator and or broken tabs that go into the machine to indicate the printer draw two is closed. Lift the printer off tray two use just one and bypass does that work eliminates the circuit board of the machine.
Nov 30, 2015 | Konica Minolta Magicolor 4690MF...
Printing stops on its own after printing a couple of pages. 2. Printing has yellow overlaps. Have changed the PCU after printer signalled change. Have rebooted, and checked correct replacement of...
SC285 is a line position adjustment error. It is possible the ID sensors are dirty. In order to get to them you have to remove the PCUs and developers as well as the transfer belt assembly. The sensors are behind the shutter that is next to where the upper most PCU would be inserted.
Mar 11, 2011 | Ricoh AFICIO SP C821DNX 50 PPM 4X550 SHEET...
Paper is inserted properly but error message keeps saying "Load paper face down in Main tray"
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Jan 06, 2011 | HP Photosmart C6280 Printer
Status light is red and paper light blinking
Alex,
To isolate the problem, please try the steps below:
Remove and re-insert the paper tray and then click Go.
Take the drum unit out of the machine and put it back in.
Here, I provided you a link that might help you:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Have a great day!
May 07, 2009 | Brother HL 5250DN Laser Printer
Printer complains: Insert Paper fully into MPF
Pull the paper tray out and look for any obstructions in there.  Check for broken parts as well such a sensor.  Sometimes they get out of position as well.
Sep 17, 2008 | Dell 3100cn Laser Printer
Error 011 Panafax 585
The extension at the back of the tray has broken off, so the machine doesn't recognize that the tray has been put back in. Solve this by taking a piece of cardboard (business card works good), fold it up and insert it into the sensor at the far left where the extension would have gone when the tray is inserted. This will trick the machine into thinking that the paper tray has been inserted.
Jul 24, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Xerox Phaser 8200 false "Replace Paper Tray" message
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Hp 3800dtn standard top bin full remove paper error
Maybe your paper sensor flag is stuck or broken if you pull the tray out of the machine there should be a little black plastic sensor flag hanging from the top middle of the slot where you pulled the tray out from if its stuck up or broken the tray will always sense its full of paper.
Jun 20, 2008 | HP LaserJet 3800dtn Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
Lexmark C534dn Laser Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
