Question about GPS
I have an opel corsa utility bakkie. the right indicator flashes on the inside fast but no indicator works on the outside , all bulbs were checked and n.f.f...... the left works fine . fuses were checked and n.f.f. ..... I replaced bulb and got new headlight , but now all has stopped and checked fuses but still flashing fast on inside and hazards flash at normal rate just no light thanks sean what could be the problem.
Mine did the same. After a while the other indicators started doing the same. The problem was the flasher unit. Cost was R830-00 for the unit and 10 minutes of labour to replace.
Kobus
Posted on Apr 12, 2014
I came across this forum cause my Opel Corsa bakkie 1.7DTI 2006 had the same issue. The right indicator would flash fast, the whole right side of my indicator bulbs did not work. The left side was fine, no issue there. Put the hazards on and only the left side worked.
I referred to the wiring diagrams in my Haynes manual for the corsa.
It said that if you could hear the relay engage while activated ( Which I did ) Then the fault would be in the wiring circuit.
However, I replaced the yellow relay ( In the engine compartment passenger side up from the fuse box ) and Wunderbar! it worked hundred percent! Cost R175. Try this as well. Could save you money.
Posted on Jun 06, 2016
Hi, have you guys ever resolved this problem?
Posted on Nov 12, 2013
Not an expert on this, but mine has the same problem and the dealership says it's the bulb housing (that makes it flash fast). There's only 2 of 3 points making contact.
Posted on Apr 18, 2011
My 2006 opel corsa utility bakkie using a lot of petrol like 7km per litre.
check fuel pressure regulator on the injector rail.also for leaky injectors. Coloneus
Mar 06, 2016 | Opel Cars & Trucks
Why do i smell fuel when i start my opel corsa bakkie 1.4 fumes coming from exhaust smell off fuel
Rick mixture or stuck choke. Get it to a garage and get it on an exhaust analyser. Will save you money in the long run with the saving in fuel. I presume fuel costs as crazy in Australia as they are in the UK.
Dec 02, 2015 | 2006 Opel Corsa Utility
Tell me where does the thermostat of the opel corsa utility bakkie sits
If you follow the upper radiator hose to the engine usually you will find the thermostat housing it will most likely have two bolts . Make sure if you replace the thermostat to have a gasket and also some gasket sealer. Good luck !!!!
Nov 01, 2014 | 2007 Opel Corsa Utility
Where is the earth wire right indicator light of opel corsa 2003 sport 1.6 situated on car
follow the wire's back from the bulb holder , the earth wire will be the one that is bolted to the car body/chassis , earth wire's are usually black
May 21, 2014 | 2003 Opel Corsa
Opel corsa 1.8 2007model left indicator repair
need put the lamp in the corect position
Jan 20, 2014 | 2007 Opel Corsa 1.4
Right side indicator not working correctly
if it is flashing too fast it means one of the bulbs either front , side or back is burnt or not making contact
Jan 07, 2014 | 2004 Opel Corsa
Right indicator not working properly what can cause this
well it can be improper contact or if its flashing fster than usual check all other indicator light if they are working and all the bulbs are not burnt, i can bet you , failure of the other makes ur indicator flash fast
Flashing service engine light flashing
you need to have the computer checked for codes, this will show you which direction and area to start testing as well give you a place to start diagnosing.
Jun 07, 2013 | Opel Corsa Cars & Trucks
Opel Corsa Utitilty 1.4i right indicators don't work even after I changed the globes
If the lamps and bulbs are ok I would initially suspect the hazard warning light switch, then the indicator switch, the multiway connectors and then the wiring.
There is generally only one fuse for the indicators and as one side is working it can be assumed power is reaching the indicator circuit.
Feb 01, 2012 | Cars & Trucks
GPS Logo
581 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
