Question about Canon Office Equipment & Supplies
Print head problems - Canon Office Equipment & Supplies
  • xhalogeekx Aug 05, 2008
    still doesnt work dude
The printer do all the set up and initialization, it is ready "on line" . When receive a new printing file it look like is ready to do so but still show "printing" in the display and nothing hapen even for hours.
No error codes at all. Please help
Claudio Cassina
claucassina@bellsouth.com
Posted on Oct 09, 2008
  • 138 Answers
Being a 13.5 year veteran and HP Certified technician for printers and plotters, just a couple small changes to your above. You need to substitute water for the alcohol, preferably distilled but not a must. Worst case clogging senarios use 25% windex (ammonia based, not sodium based) and 75% water. Alcohol will delaminate some nozzle plates and render them useless. Use wicking action with a damp paper towel rather than banging the cartridge. Banging the cartridge has a negative effect on the nozzle heating chambers and further damage the cartridge. Simply rest or prop up the cartridge on the damp paper towel for a few minutes with the nozzle plate in contact. If the cartridge is still blocked try it with a little windex sprayed on the damp paper towel. Hope the above helps clarify.
Liked your above article... nice to see people helping others.
Posted on Aug 05, 2008
    Guru:
  • 859 Answers
This problem is extremely common. More so, if you've refilled your own cartridges or purchased refilled ones. Canon is real specific on this as their pigment is of such a size to not erode the nanometer nozzle holes in the print head.
Now, to fix your issue. You need paper towels and 97% rubbing alcohol.
Do this outside. This is important because of the fumes.
Remove the print cartridge, soak a paper towel well with the alcohol. Wrap the towel around the print head and put slight pressure against the nozzle portion. While doing this knock the cartridge gently but sharply against a hard surface. Repeat this keeping the towel moist and until ink runs freely into the towel.
You can now use the print head again.
Once you succeed with this and only then rate this as Fixed please.
If you run into any problems or have a question, ask me using the comment box below.
Getting you fixed up is the point and doing so, sooner or later is important to we who work in the Free Forum. Earning a Fixed is what we take pride in. So, if you'll work with me I'll work with you.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Aug 05, 2008
    Is you print head clogged? And have you tried the deep cleaning cycle and if so how many times?
    Worldvet
Epson stylus r240
please clean print head and if issue still than remove print head and put in print head cleaner for 24 hours. after inject liquid in print head and than refax print head. if issue is still than replace print head.
Jul 09, 2013 | Epson Office Equipment & Supplies
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Have an iP90, but the color ink won't print.
When Printing Becomes Faint or Color are Incorrect, the Print Head Nozzles are probably clogged.
Follow the procedure below to clean the nozzles.
Print the Nozzle Check pattern to determine whether the ink ejects properly from the Print Head Nozzles.
a) Using RESUME/CANCEL button.
I) Ensure that the printer is turned on, and then load a sheet of Letter Paper.
ii) Hold down the RESUME/CANCEL button until the POWER lamp flashes twice, and then release it immediately.
b) Windows
i) With the printer on, load a sheet of Letter-sized plain paper in the printer.
ii) Open the Printer Properties.
iii) Print the Nozzle Check Pattern.
Click the Maintenance Option from the Menu.Then click Nozzle Check from the pop-up menu. Then click Print Check Pattern.
iv) When the confirmation message is displayed, click OK.
v) Confirm the nozzle check pattern.
Examine the Print Nozzle.
Step 2 : Cleaning the Print Head.
a) Cleaning the Print head using RESUME/CANCEL button.
i) Ensure that the printer is on.
ii) Hold down the RESUME/CANCEL button until the POWER lamop flashes once, and then release it.
b) If you pressed the Cleaning button on the Examining the Nozzle.
Check Pattern screen displayed after the nozzle check patter was printed, start the Print Head cleaning procedure.
i) Ensure tha that the printer is on.
ii) Open the Printer Properties dialog box.
3) Start Print Head Cleaning,
- Click the Maintenance tab.
- Click Cleaning.
- Select the Print Head to be cleaned, and then click Execute.
Print Head cleaning starts when the POWER lamp starts blinking,
Important : Do not start any other operations until the Print Head Cleaning finishes. This takes about 60 seconds.
4) Check the Print Head condition.
i) Click the Print Check Pattern in the nozzle Check dialog appeared after cleaning are done. When the confirmation message is displayed, click OK. A nozzle pattern will be printed. Do not perform any operation until printing is completed.
ii) Observe the printed nozzle check pattern to check the Print Head condition.
iii) If the problem persists after you perforned Print Head normal cleaning 3 times, execute Print Head deep cleaning.
Step 4 : Print Head Deep Cleaning.
If print quality does not improve by standard Print Head cleaning, try Print Head deep cleaning, which is a more powerful process and comsumes more ink.
1) Ensure that the printer is turned on.
2) Open the Printer properties dialog box.
3) Start Print Head Deep Cleaning.
i) Click the Maintenance tab.
ii) Click Deep Cleaning.
iii) Select the Print Head to be cleaned, and then click Execute.
iv) When confirmation message is displayed, click OK. Print Head deep cleaning starts when the POWER lamp starts blinking,
Important : Do not perform any other operations until the Print Head deep cleaning is completed ( about 2-3 minutes).
i) Print a nozzle check pattern to check the Print Head condition.
ii) If the problem persists, perform step 3 again.
iii) If the problem persists, the printer may have run out of ink.
Replace the ink tank.
iv) If the problem persists, the Printer Head may be damaged. Contact your dealer or Canon Customer Care Center.
Hope this helps.
Have a good day.
Dec 04, 2009 | Canon PIXMA iP90 Mobile Printer
Prints, but only every few lines. Those that print look normal, but in-between, they are faded. A roller problem?
It's clogged print head problem.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 09, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
HP L7680 Print Head Problem
Sometimes the circuit strip that sits at the back of the printhead carriage is the problem due to moisture, ink soiling, etc...
To clean these you need some cotton buds (like you use to clean your ears) and gently clean the area at the back of the printhead carriage (where the printheads slot into).
This removes any ink, or moisture that could be causing a short circuit or similar.
Nov 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Print Head Problems
Try cleaning the print hade sensor useing alcohol.it is by the home position whera the print hade is installed.
Apr 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
325 people viewed this question
old marine
old marine
