Question about Microwave Ovens
It was purchased November 2010, lately there has been a smell of gas behind the appliance. Had gas appliances checked but it is not them. Hotpoint not helpful, need to know if there is a gas container in that appliance
    Genius:
  • Microwave Ovens Master
  • 1,466 Answers
No gas to micro. why not remove it and try elsewhere, could be dampness?Good luck
Posted on Apr 01, 2011
How do I get a manual for a Hotpoint over-the-stove microwave?
Hotpoint is part of the GE company. Manuals can be printed off GE's site in the appliance customer support section.
https://www.geapplianceparts.com/store/
Feb 26, 2015 | GE Hotpoint Over-the-Range Microwave
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
I am getting ready to update my appliances. I want to know the exact size of the appliances I currently have supplying you the model and serial numbers. Double wall oven: RDE 2400 P2 Model Number, MI 34...
OK, now replacement of major appliances in your home should be left to someone that you don't even know. Why should I recommend Whirlpool replacement appliances. This is your decision.
It depend on what you want in appliances; such as, top quality, the most expensive, mid level appliances, and many other factors involved in your choices of replacement appliance.
Mrs Alecia William you need to talk it over with your husband and friends, do your research on appliances on the internet. Just remember this....Everybody will give advise on what appliances to buy but the final decision will be left you and your husband. I could recommend different types of appliances, but who am I! Please do your research. All I can recommend is BUY AMERICA. And yes, United States does make all the appliance that you have mentioned. GB you...stewbison
Sep 05, 2011 | Whirlpool Microwave Ovens
My Hotpoint microwave oven just shut off while it was being used. Now there is no power at all. Could it be a fuse? How do I replace it if it's the case?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 01, 2011 | Hotpoint RVM1435 Microwave Oven
No power to oven. Receptacle it is plugged into shows power
Hope this helps.
Feb 27, 2011 | Hotpoint RVM1635 Microwave Oven
Need to convert nat gas to lp gas have a in the counter cook top
Most manufacturers of gas appliances offer conversion kits to make switching between LP and NG fuels for ranges, dryers, etc. relatively painless.
First, you'll need to collect the manufacturer's name, appliance model and serial numbers. Then, contact your choice of either the place of purchase, or shop the part to authorized parts resellers in your locality or internet for the correct kit and best price. Use only parts designed for use in your particular appliance.
I hope this helps & good luck! Please rate my reply - thanks.
Feb 03, 2011 | Frigidaire Microwave Ovens
Panasonic NN-SD277. Almost 3 years old. We pressed start, it went for about a second (may have made a sparking sound) and then it just lost all power. There is still power to microwave but no lights are...
We also have this same microwave. It is less than 3 years old. We've had nothing but problems since we purchased it. In November 2010, the microwave made a crackling sound and then BOOM! Nothing. I have been back and forth with Panasonic. I refuse to pay for the repair on an appliance that is less than 3 years old. It's ridiculous!
Anyway, the problem t is an issue with their inverters. Google it and you will find page after page of the same story.
Jan 21, 2011 | Panasonic Microwave Ovens
Purchased G.e. JES2051 microwave May 3rd, 2010. When I press start, it trips the ciracuit breaker every time. I had the braekr changed and it would still trip the breaker--every time. I have moved the...
Verify the manual or the sticker in the back, check for the electrical rating (AMPERS) 15 for a house appliance and 20 for commercial type oven, if your electric system meets the ratings then (if it is still under warranty), go to the store have it replaced, with all the tests you did, it is definitely defective.
Jan 12, 2011 | GE JES2051 Microwave Oven
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
Microwave not working
The main controller board, or one of the power supplies has failed and require to be replaced.
You should take the microwave oven in for an estimate. I strongly suggest to not service this type of appliance yourself unless you are trained and experienced in microwave oven service.
There are many safety issues when servicing microwave ovens.
Jerry G.
Apr 04, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
