Question about Samsung Televison & Video
My Samsung LE40N87BD 40" LCD tv will not turn on,
  • 230 Answers
SOURCE: No longer turns on
It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
Good luck with it.
Posted on May 25, 2009
  • 3 Answers
SOURCE: Magnavox 19MF337B/27 LCD TV problems
The bad capacitors in this set are usually NOT on the power supply--they are on the other (logic) board. You will find several bulging capacitors there. Replace em all....
Posted on Nov 17, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
micromatikal
  • 2777 Answers
SOURCE: I have a viewsonic N3235W
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You can test the voltage output from the power supply if you wish... that will show if it is indeed the culprit which I think it is. If you don't want to mess with that you will want to contact a local TV repair person in your area if you are sure this is out of warranty, more on that in a bit here. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need.
So sorry that I don't have better news but it is definitely a power issue internally. Please reply to my answer here with any questions or comments and I can help you for sure...
Thanks
Tim
Posted on Nov 06, 2010
  • 1267 Answers
SOURCE: Samsung LN46A550 LCD power on/off
Apparently this is a known problem with flat panel TVs made a few years ago due to bad capacitors in the power supply. This same problem appeared in computer mother boards at about the same time so that the capacitors went open or shorted causing problems.There is videos on You Tube that addresses this problem see: http://www.youtube.com/watch?v=ZccykxrtX9g as a starting point and look around for other repairs
Posted on Jan 25, 2011
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
https://www.youtube.com/watch?v=2TImpsUnGtI
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
reviews.lcdtvbuyingguide.com/samsung-lcd.../samsung-un40eh5000.ht...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV
www.amazon.com/Samsung-UN40EH5000.../B00723...
Amazon.com, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Is it worth to replace the LCD panel ?\ The Replacement LCD panel code is BN95-00604A How to do the LCD panel repleacment
Considering the price of a TV I'd say not.
Did a google search and found this site using BN95-00604A: http://www.encompassparts.com/item/9186449/SAMSUNG/BN95-00604A/PRODUCT_LCD-AMLCD where they list the part at 565.00 including a 102 core charge which I presume would be returned to you once the core is received. It is unknown if this source is the only source, that this source would actually sell the part to anyone other than authorized service providers, it also doesn't address shipping costs or taxes and damages that may occur in transit. Also from this site, I learned that this part is used in a Samsung UN40ES6100FXZA 40-Inch Led 6100 Series Smart Tv
Here it is on Amazon for 829 with free shipping: http://www.amazon.com/Samsung-UN40ES6100-40-Inch-1080p-Black/dp/B0076M04QU
Samsung UN40ES6100 40 Inch 1080p 120 CMR Slim LED HDTV Black 2012 Model
Apr 28, 2014 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
What is an Samsung UN40D6500 LCD TV? LCD TV Liquid Crystal Display, which stands out from the bulb or CCFL Cold Cathode Fluorescent Lamp, which is a thin tube like a drinking straw. By horizontal long as...
Hello
What is this? Are you trying to take a class to everyone to thie world, how the LCD TV works? I think you be a student, not a professional. If you wer a professional, you may won't dare to post this as a problem. OK.
Feb 11, 2012 | Computers & Internet
When I turn TV on with either the remote or push button on front, it automatically switches on and off several times before "catching" and staying on
yes ,, the problem on ur tv is the power supply , u have bad capacitor , now this problem is under recall by samsung , u may want to call 1-800-samsung that way u dont has to pay for repair
Nov 30, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Televison & Video Logo
369 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
