Question about Abit IN9 32-MAX Motherboard
Red light on abit kn9 motherboard next to power. Beep noise 1-2-1-2-1-2-1-2-1-2-1-2-
  • Anonymous Mar 21, 2014
    no usb
    red
  • 656 Answers
Check the memory card remove the memory from the socket and clean them with a cloth insert it if the beep still occur change the memory card and also check the graphics section in the motherboard to verify insert a new graphics card suitable and switch on the system
Posted on Apr 01, 2011
This is going to sound vague, but currently a friend and I are working to get this desktop PC working that has a KN9 SLI motherboard installed on it. Currently, the issue is: The computer turns on, a red...
Try checking the jumpers on the motherboard. A lot of the SLI compatible boards have jumpers that need to be configured properly. You can find out the positions by checking the motherboard manual. Are you using an SLI capable video card or is the video onboard? I just ask because I had the same problem once while trying to install an SLI video card. I had no picture on the monitor and I couldn't figure it out for the longest. Finally I found the answer in the motherboard manual and it turned out to be a jumper that was set wrong. Hope this helps.
Mar 23, 2011 | Abit KN9 SLi Motherboard
After many years use, I recently developed a problem with system temporarily freezing, screen flashing and then restarting. I have tried reinstalling the os, changing the hdd and monitor, with no change....
Try a new power supply. A flaky output voltage can cause all kinds of weird problems, but people often overlook the supply if the system comes on at all. The other possibility is that something on the motherboard is acting up, but I'd try the supply first. It's an inexpensive part, and you may be able to borrow one for testing from a computer geek friend, or even take one out of another computer temporarily.
Good luck and thanks for using Fixya!
Dec 05, 2010 | Abit KN9 Motherboard
No video, Abit KN 9 Ultra Intermittant long beep, can't answer for beep code anyone know?
A long beep signals that no memory is detected ; test the memory sticks and reseat them.
Dec 02, 2010 | Abit KN9-SLI Motherboard
Abit kn9 sli, my problem is this, when i turn my pc on the fans spin for about one second then it all turns off. the power lights on the motherboard stay on but it wont power up at all. if i turn the power...
Are you sure the 4 pin connector is going in correctly? Some motherboards have an 8 pin socket, and the connector can be placed in improperly. The symptoms you describe indicate a dead short on the power line when plugged in.
Jun 20, 2010 | Abit KN9-SLI Motherboard
Lost cd from motherboard so cant find good drivers and media
Access ABIT's web-site: http://www.abit.com.tw/page/en/
and select and download and install the appropriate drivers.
Oct 29, 2009 | Abit KN9 Motherboard
Up motherboard beeps and there is no display can
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml
http://www.pcguide.com/ts/x/sys/beep/index.htm
http://www.computerhope.com/beep.htm
Oct 14, 2009 | Abit KN9 Ultra Motherboard
I just received a hand me down system with the abit kn9-sli motherboard. After installing a new amd 64x am2 6000+ processor and a new hard drive...when I powered on the system...the systemboard speaker...
Usually the sound is called bios beeps. They let you know in advance if there is a problem.
Usually a high low bios signal ( like an old german siren) means a cpu issue.
Check the processor and cooling fans, and check it's temp....take two aspirins and call me in the morning...LOL :)
Hank
Jul 30, 2009 | Abit KN9-SLI Motherboard
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Apr 18, 2009 | Abit KN9 Motherboard
Abit IN9 32-MAX Motherboard Logo
264 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
