Question about Polar Exercise & Fitness
Chest strap stopped working - Polar Exercise & Fitness
    Guru:
  • 347 Answers
This can be caused by a number of factors from dead battery to lost signal. I have on my tips and tricks page a checklist for HR signals and causes for disruption.
If it is the Battery then...
#1 - Hard strap, only remedy is too replace, batteries are sealed in.
#2 - Soft strap (wearlink), these have a replaceable battery 2025 and you can do this yourself.
Posted on Apr 01, 2011
Sportline cardio 660
Try to humidify contact area on chest strap(each side front). Also batterie weak in strap?
May 11, 2013 | Exercise & Fitness
Sometimes, my watch gives me crazy readings such as 221 bpm at rest for my heart beat when I use the chest strap transmitter. What causes that and how can I prevent it? Could it be my WiFi internet network...
Make sure your chest strap is a good fit so it doesn't move, not too slack. Also you need to wet the sensors so that you get a good connection. On the Garmin ones they recommend using an electrode gel but that costs money and I find spit/saliva works just as well.
Jul 25, 2011 | Sport & Outdoor - Others
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How do I enable my EFX 544 to give my heart rate while wearing my polar heart rate chest strap?
If the EFX 544 has polar Heart Rate attach to the upper electronics your chest strap should be transmitting and the unit should be receiving. If your chest strap is more than 3 yrs old usually the battery will die and needs to be replaced or you have a defective receiver and will have to be replaced
May 17, 2010 | Precor C956i Treadmills with HR /...
Doesn't synch with heart monitor
Hmmm. Trick one without seeing the unit.. The most obvious is that the battery in the chest strap is dead. If it's one of the sealed ones then the whole chest strap will need to be replaced, if not then it'll be a standard watch battery. I should be clear from the chest strap if the battery can be replaced.
If both batteries are ok then try to turn on the Forerunner, put on the chest strap(make sure to lick the back of the sensor or dip it in water to make a solid connection, strange I know but that's what they reccomend). Then hold your wrist wearing the Forerunner a couple of inches from the sensor on your chest, sometimes needs to be for 30 seconds or so.. All going well that should do it.. Beyond that you're into the software in the Forerunner itself and that has to go back to Garmin..
Oct 02, 2009 | Garmin Forerunner 305 GPS Receiver
Passenger side shoulder strap doesn't tension properly on 88Vette
have you checked the tension when the brakes are being applied some of the newer vehicle seat belts don't tighten until you step on the brakes
Jul 15, 2009 | 1984 Chevrolet Corvette
Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Open Questions:
Hi I have just bought a Sole F85 (2016/2017) treadmill. I was advised it the F85 would work with my Polar H7 and H10 heart rate monitor as these synch with my iPhone and V800 Polar devices H7and H10 are both open source 5kz analogue signal however the F85 does not pick up the signal from the Polar HRM why is this as I was told F85 operates with and can receive a 5kz signal. Polar are leaders in heart rate monitors and all the gym equipment I have used for the past 15 years has been compatible with the Polar Product I am starting to use the Sola Fitnesss application but the F85 Treadmill I have just purchased does not appear in the list for connections there is a blank line which when selected sometimes connect to the F85 via Bluetooth. There appears to be a bug in the software. Also there is connectivity to other apps Fitbit, HealthKit, Mapmyfitness but there is no connectivity to Polar Polar are the leaders in heart rate technology and one of the largest producers of HRM products so when can the Sole Fitness application be developed to include an interface / connectivity with the Polar Flow and Polar Beat applications. Also can the Sole Fitness application be developed so is can use via Bluetooth a Polar heart rate monitor (chest strap)? If Sole Fitness can pick up HRM data from Polars H7 or H10 via Bluetooth then it could be an interface to the F85 Treadmill, is this possible as part of the Some Fitness application development. Also I have noticed that the pulse readout is totally inaccurate as my V800 says 130 bpm and the display on the F85 says 78 Any guidance would be much appreciated
Nov 04, 2017 | Polar Exercise & Fitness
Exercise & Fitness Logo
749 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
