Question about Honeywell Heating & Cooling
Hi, Can a honeywell wall controler pro 5000 use on a bravis ducted heating? Regard
    Scholar:
  • 133 Answers
I think so. Can you give me the terminal designations on the thermostat? EXAMPLE - H1, H2, H3 etc., G, C, Y1, Y2, etc. (I don't have a 5000 in stock to look at)
Posted on Apr 01, 2011
I took my Honeywell focuspro 5000 non programmable thermostat off the wall to change the batteries and I put new batteries in it and back on the wall and now my air conditioner wont come on do you kno
I can only suggest that you check and make sure all of the pins are straight and not bent over from trying to align the back plate with the back of the thermostat. Ive done it and its easy to do if you are not very carefull.
Sep 19, 2014 | Honeywell TH5110D1006 Focus PRO 5000...
Dont no how to work central heating system
Honeywell Focus Pro 5000 non programmable is the easiest heating cooling thermostat that I've seen.
Dec 23, 2011 | Heating & Cooling
I have a Honeywell Focus pro Series 5000 Model Th5320U. How often should this thermostat cycle in an hour?
Hi, That depends....some on how you have it set up and some on how the building is responding to the unit....bottom line, I cannot give a definitive answer...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Aug 05, 2011 | Honeywell Heating & Cooling
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
Honeywell Pro 5000 wont bring Heat on
have you programed the tstat for your system? look at your installers book.
Oct 07, 2008 | Honeywell Electronic Programmable...
I have had a new honeywell humidifier installed. The problem is the control H8908B. HE INSTALLED IT FIRST TIME ON A DUCT RIGHT NEAR THE FURNACE AND IT FEEL OFF . Melted . Then came in and moved it away...
After the air leaves the fan ,this is called supply air ,before the air enter the fan which sucks air into the fan --- on the flter side --is called the return air!
Sep 12, 2008 | Honeywell Heating & Cooling
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
121 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
