Question about Samsung AS18A6RB Air Conditioner
New installation HI I fix new samsung 18000 and the technical gay connect all wires and pipes find but the indoor unit and outdoor not working no lights no any think at all we check every think and electricity from plug to outdoor and indoor find can you hlep me about this problem
  • ahmdhass Feb 01, 2009
    thank for help the problem from electronic chip inside indoor unite we replaced by new one
  • Anonymous Mar 26, 2014
    I require a manual on this product that tells me pipe size's and maximum distance from indoor to outdoor.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check the power to the door switch and make sure the door around the fan motor is on tight. and pushed in.
Posted on Sep 06, 2008
SOURCE:
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Samsung Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
What does error code E6 mean?
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
Carrier ckc outdoor unit not starting automatically after installation
It is important that the connections from the outdoor unit is wired to align correctly with the indoor unit where the main control panel is located . The outdoor unit compressor is switched on from the processor here and so it is marked in detail to connect the wires.
Now the if the indoor unit is not powering then there is fault in the main control panel and you need to get help as this is a new unit and warranty should not be compromised.
It is possible that the new unit has a damaged control panel or power and so does not power. take help.
Aug 22, 2011 | Carrier 38CKC042 Air Conditioner
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We have a P8? CAN'T FIND MANAUL
P8-Abnormality in outdoor unit.
1.Wrong wiring of indoor/outdoor
connecting wire.......................Check the indoor/outdoor connecting wire.
2) Reversed phase......Change the connection of electric wiring.
3) Protection device is working........ Check the protection device.(LP,HP)
4) Damaged outdoor coil thermistor.....Measure the resistance of the outdoor coil thermistor.If the resistance is normal, replace the outdoor controller board.
5) Check out door coil is cleaned. If not do it.
thanks.
Jan 30, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Samsung AS18A6RB Air Conditioner Logo
82 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
