Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer CD1015 Hi there, i have the following Problem with a Wurlitzer CD1015 Model: CD Spin Motor will not start, the grabber takes a cd, lay down on the turntable, the grabber takes the cd after 15sec. and put aside to the carousel. The disply shows Number4 but no reaction for programming the jukebox. If i try to set it to the "Service-Mode", no reaction. No relays will switch, no LED on the control-Board shines. I have changed already the Transistors on the control-card. Does somebody knowing what the problem is? Sorry for my bad english... Thanks for your advice Greetings from Bavaria Reno
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Your problem is usually caused by a faulty CD player or a faulty CD control pcb (under the CD player).
The leds Z and M on the credit unit only flicker when the carousel turns.
Posted on Aug 09, 2008
Wurlitzer 1015 cd player that wont read the cds bot the drive motor spin real fast ???
That usually means the Laser can not pick up the CD surface. I have not worked on Wurlitzer CD but have worked on hundreds of other units and the technology is the same. It could be the platter distance is too far from the pickup or that one of the six laser pickup has burned out to allow correct tracking. There is a Focus OK signal that has to be satisfied first, then spin up and data reading of the TOC. f it can not do that they may spin wildly.
Dec 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
Model- 1015CD Wurlitzer "One more
It sounds like a communication problem between the Selection & Credit Computer (SCC) and the CD Control unit, or perhaps a defective player (SCC is telling it to play, but it can't). There are different troubleshooting procedures, depending on which player version you have. Please email me and I'll give you a phone number where you can call me for further help
May 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
Disc player picks up CDs, puts them down, they spin and then it picks them back up without playing them.
In my experience this is usually a problem with the CD player or the CD control unit. I have had this problem with my Wurlitzer CD Carnegie and I solved it by simply taking a Q-tip, moistening it with rubbing alcohol and lightly rubbing it on the CD player's laser lens and then using the other side of the Q-tip to dry it. Over time dust and dirt can build up on the lens causing read errors, which in turn cause the jukebox to reject the CD. If that does not help, I would suggest looking into replacing the CD player or the CD control unit.
Mar 26, 2011 | Wurlitzer Jukebox CD Player
Will pick up cd lay it down but will not spin.
Troubleshooting varies with the seven different CD player versions installed. Please email me for further troubleshooting assistance, tech@wurlitzer-ohio.com
Jan 17, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a Wurlitzer 1015 with a 50 CD Changer (CDM-12). The CD loads on the player but does not alway start to spin and after a while the CD is returned. Sometimes the CD does start, but it sounds a...
I can fix your problem. It is either the CD player itself, or the CD control board underneath. Please email me for the instructions to remove these parts to send in for repair, tech@wurlitzer-ohio.com.
Jan 11, 2011 | Wurlitzer Jukebox 1015 One More Time...
Jukebox CD Player: wurlitzer 1015 cd player take about 5 minutes befo...
Faulty CD player or faulty control pcb under the laser unit. That's assuming it is not spinning at all until ages after it has put the Cd down.
May 16, 2010 | Wurlitzer Jukebox CD Player
Cd holder not turning
I just got mine going last night, it appeared not to be working. I removed the circlip under the carrier and lifted it off. I removed the two carrier motor screws and found the motor was working. The motor can get to a certain alignment with the gear wheel where the wormgear binds and won't turn. I replaced the motor and tightened the screws placing the motor in just the right location to spin the gear freely then greased the gears. I also wiped clean the underside if the carrier and the rubber 'o' ring that spins the carrier to improve grip.
Also, Two microswitches are responsible for completing the motor circuit and if they are broken or out of whack you can have problems. One switch on the carrier latch and one in the grabber arm. Fuse 6 in the amp is also required and also runs the CD player.
Feb 28, 2010 | Wurlitzer Jukebox 1015 One More Time...
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer princess
laser trouble replacing laser should fix it
Feb 21, 2008 | Wurlitzer Jukebox Princess 120-Disc CD...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
110 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
