Question about Hotpoint Ultima WF860 Front Load Washer
Everytime i put my washing on it goes onto test mode. I reset it so it is back to the on screen and then evertime i press a cycle it goes back onto test mode. Ho9w can i get it out of test mode and back to normal?
    Brigadier General:
  • 6,277 Answers
You will have to look at the manufacturer's plate, probably on the back of the machine to find the appropriate date then-
Date code 39, March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39, March 2005 to date code 42, June 2005
Press the cancel button and the machine should return to normal
Date code 43, July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
Good luck,
John C
Posted on Apr 01, 2011
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Have a new ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine now stays in drain mode, stops after 3 minutes, door unlocks and start/ pause button flashes. How do you...
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Feb 28, 2010 | General Electric WCVH6800J Front Load...
My samsung blue flip cell phone, everytime I press 369 or#....
If you notice the 3,6,9, and # are all on the same column. There is probably some corrosion under the keypad from a spill or moisture. If cleaning the membrane switches won't work try replacing the keypad (the electronic portion, not the rubber). Repost if you need instructions. I can put some parts up on ebay for you too.
Aug 17, 2009 | Samsung Cell Phones
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine
Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
I nearly called an engineer once because my daughter causes it all of the time!
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
Reset the washer
GE Profile Harmony
1 press power ( to wake up washer)
2 press Home ( it may already show HOME)
3 press HELP
4 press and hold MY CYCLES and BACK (for 3 to 5 seconds)
the service mode diagnostics screen will come up
it will show what errors are recorded..( if more button is displayed then also go to next list)
be sure to write them down exit will clear the codes and run a test
let me know what it tell you I can help...
Aug 21, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Hotpoint wf860
the applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Feb 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
129 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
