Question about Car Audio & Video
Im having problems with my car stereo its a 6 CD changer GX-201JE stereo for a 2005 Subaru Outback. When I try to eject one of the CD's it says Error 99 and it can not change disks...Please help
ZJLimited
  • 17970 Answers
SOURCE: HI, My 6 cd changer
Error 99 is CD not up to speed. Either the CD is slipping, Defective CD, pickup is unable to read sectors and is either dirty pickup or pickup going bad. Is it always the same CD you are playing? Is the CD smudged with finger prints or dirty? If not suspect the CD itself.
This will require Repair or Replace, as E-99 is a classic malfunction & unit will need to be taken apart, "unless" there is a CD stuck in the Unit.
If you have loaded a Blank Cartridge & clicked Eject & found no extra CD, then you will need to have a Reputable Shop Repair Typically this is the Logic I.C. & / or the Servo Motor.
Sometimes you can find the same Unit on E-Bay, Craigs List, etc for less than Repair
Changer Error Codes:
E-00: Poor Cable connection.
E-01: Magazine not properly set in changer.
E-02: No Disc in magazine.
E-03: CD does not have selected track number.
E-04: Disc is dirty, upside down or unreadable.
E-10: No data is recorded on the MD. The player plays the next disc automatically.
E-99: Changer malfunction, disc may be caught in machine or changer requires service.
Hope this helps.
Posted on Jun 03, 2011
SOURCE: 6 cd changer mustang stereo
How do you manually eject the cds? I put in a new cd and it went in and does not recognize it and says slot is empty and now none of my cd's work....please help///
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: Jeep RDS CD Problem
Did you change the battery ? If so try disonnecting and reconnecting the CD changer.
Posted on Dec 28, 2008
SOURCE: 6 disc changer will not eject cds==
I had the same problem for months. I checked the owners manual, checked the fuse box, everything I could think of. Then, today, I did some online research and someone said one of the CD's is probably just jammed or slipped out a bit. The suggestion was to gently slide a credit card over the disk (through the door/slot, which in my case was partially open). I just tried it. The door closed and the message said "initializing". It worked! The CD player is back to normal.
Posted on May 29, 2009
  • 1986 Answers
SOURCE: Stuck Cd in 2003 Subaru Legacy Outback
pull out the fuse for your radio and turn the ignition to the on position and wait 10 secs. Then turn off the ignition, replace the fuse and turn to the on again. It may work as I've done this to other cars which have had cd's stuck
Posted on Sep 18, 2009
2005 subaru outback ll bean edition, center console or "bezel" is one plate with 6 cd changer, heat, etc.. all on same face. 6 cd changer will not work , i have 6 cd's stuck in there, just...
Is car automatic? dont matter, open arm rest and take out every screw u see, dont be scared move foward. pull up on shifter plistic beseil, then to ashtray,2 screws under, coffee thing gotta go.comon guys? can ya get gas in it? its looks like it will brake,just give it a quick ****...
Jan 04, 2011 | 2005 Subaru Outback
05 G6 radio reads cd changer errror
Im having the same issue ..and actually seen this issue on alot of message board or websites..starting to think its a manufacture issue
Apr 17, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Sep 18, 2009 | 2003 Subaru Outback
I have a 6 disk changer and a single disk on my
you can try looking for a reset button on either or both items. the button would only be the size of a pin. you could use the tip of a pencil to reset. if you don't find this button, try disconnecting the battery for a couple of minutes to reset the system. my guess is that outside of that, you have a more serios problem. next step - unplug the changer from behind the radio and see if you still have the same problem with just the radio. and if you are behind the radio to unplug the changer, unplug the radio and plug it back in, especially if you couldn't find a reset button.
Sep 13, 2009 | Car Audio & Video
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
CD Changer in RX330 Lexus 2004 shows error 4
I just fixed my 2005 RX330 CD changer jam, and saved $800-1000. It was easy, if you first spend $6 at:
http://www.carstereohelp.com
Here you will find pics and instructions on how to remove the stereo/changer. Mine was a Pioneer, and the stereo came out in 5 minutes. I could not find instructions how to take it apart, so I experimented a little. The secret was to take the top lid off the changer - 9 little screws, and a piece of black tape. Under the lid, I found my problem - a CD had been inserted too soon (the WAIT sign actually means what it says!), and I just lifted it off the top plate. Under the plate I could see 2 more CDs, in the 6 slot holder, but they seemed to be free and not jammed. So without reassembling the stereo, I plugged it back in. The changer cycled, I hit eject twice to get the other CDs out, and all is well.
Mar 21, 2009 | Car Audio & Video
CD Changer is stuck
drop the faceplate, there should be a tiny hole you can push a paper clip in. push in a little bit and it should eject. good luck
Nov 30, 2008 | 2005 Subaru Outback
CD player (6 disc changer) "locked up"
Take it to the dealership, your G35 should have a 4 year bumper to bumper on it. They'll replace the radio under warranty most likely.
Jul 23, 2008 | 2005 Infiniti G35
Car Audio & Video Logo
186 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
