Question about LG WM-1480FHD Front Load Washer
There is water leaking from the bottom of the door. Is a new door seal available and can this be fitted by the average DIY person.
    Genius:
  • LG Master
  • 1,467 Answers
Yes and Yes again,you may want to visit utube .com they have videos on how to fit a Door Boot Seal.Make sure its just the seal first just in case.....
Posted on Apr 01, 2011
My GE washer is leaking from the bottom when it begins to fill. the tub is also loosey goosey. I have a fllod in my kitchen need help?
Sorry about the flood in your kitchen. I take it that your GE machine is a front loader. It sounds like the rubber seal round the door is perished or damaged. When water starts to fill the tub the "faulty" seal lets the water back out again.
The seals are not easy to replace by the average DIY person but can be done. If you choose to replace the seal yourself let me know and I can perhaps talk you through it.
Hope this helps.
Mar 04, 2011 | Washing Machines
Fridge gives ice and water thru the door. The water line coming out of the bottom of the door is leaking. The line comes out from under the door with a couple inches of tubing that "plugs" into a connector...
That connector is known as a John Guest fitting, and they will sometimes leak. Make sure the tubing is firmly pushed into the fitting on both ends. If it still leaks, you will need to get a new John Guest fitting. Your local appliance parts supplier should have them, or they are readily available online. You are looking for a fitting that is 5/16 of an inch on both sides. If a new fitting dosen't solve the problem, your tubing may have a pinhole leak in it, and would need to be replaced.
Sep 29, 2010 | Refrigerators
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
The top draw has a small leak in the back. Its about 5 years old. How do I pressure the lines to find the leak?
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks
Rylee
Hi
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a kitchen aide dishwasher ~ only about 6 yrs old ~ and it's the higher end model with the Wood panels , anyway , Its leaking water on the bottom ~ Is that the main seal ? and How hard is it to...
Hi
Thanks
Rylee
Sep 15, 2009 | KitchenAid Dishwashers
Leaking washing machine - hotpoint aquarius 1100 - wm63
water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
LG WM-1480FHD Front Load Washer Logo
153 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
