Everytime I send a document to our HP CP5225 printer the printer pauses. It is switched on and everyone else can print. I have tried reinstalling drivers but am now stuck for ideas :(
  • 17,129 Answers
When you un-install and reinstall please have your Printer removed off- the cable taken off from the PC . Connect only after the new installation is done as the PC will recognize the printer as a new hardware and install.
hope this works or your PC has errors in the OS.
Posted on Apr 01, 2011
HP CP5225 printing from iPad problem
HP has a list of solutions for print quality problems. Have you tried all the solutions suggested here?
Troubleshoot problem for HP Color LaserJet Professional CP5225 Printer...
There were also a couple Mac specific solutions available (links look the same but are different). Both solutions are about prints being different than expected.
I am an HP employee.
Apr 20, 2013 | HEWLETT-PACKARD CP5225dn Laser Printer
Hi I have a HP LaserJet 1320 Printer and when sending multiple documents it is pausing between them. I have to press the Green button to make them print, until the start of a new document when I have to...
Is the paper size set on the computer for the size of paper you are printing to?
Usually if you have to give a 'thumbs up' to the printer is because it is trying to print on an different size paper.
Aug 09, 2011 | HP LaserJet 1320 Printer
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
After pausing a printing job, my printer has gone offline
Go to Printers & Faxes, open your printer (the window where you see the documents being printed), and from the upper menu leftmost item (Printer) uncheck the option "Work offline" or similar. Then try resuming or restarting print.
Jan 30, 2010 | HP DeskJet F380 All-In-One Printer
Displays document info on LCD
you need to get whoever is in charge of you printer management to change the setting on the printer so it only displays the printer name or whatever like the ip address. he is the only one who can do it for you ok. i know as i do that myself lol. hope it works out for you and good luck
Aug 31, 2009 | HP LaserJet 5550 Printer
My hp deskjet 3550 does not print
Unistall the printer(software) then let Windows reinstall the printer, only you have the drivers downloaded(from website link below) and tell it , the computer, where to find them, when asked.
http://h10025.www1.hp.com/ewfrf/wc/product?product=82029&lc=en&cc=us&dlc=en〈=en&cc=us
Feb 15, 2009 | HP DeskJet 3325 InkJet Printer
Strange printing issue.., need assistance ASAP!!
when it receives the test page and doesn't react
1-does it go back to ready?
2-do you have to physically hit ther green button?
If everyone else can print ok then it can't be the printer !!!!
and you can ping it with no problem,
1-are you sure it is set correctly go to the properties setting under device settings is everything ok.
2-I suspect his driver is bad, try to reinstall.\
3-you can try to do a cold reset, although I don't think it will do anything since it's mainly one user problem.
Aug 07, 2008 | HP Color LaserJet 2600n Printer
HP Photosmart 3210
Try reinstalling your display drivers. you'll be surprised how dependent printers are on display drivers. Try changing the font as well.
Do you get any error messages once you click the print button? is it sending to the correct printer?
Jun 15, 2008 | HP Photosmart 3210 Printer
122 people viewed this question
jasbo
jasbo
