Hi, i have a haier AA 6kg washing machine, and the glass door is being rubbed by the metal drum inside causing it to spark inside the machine and mark all my washing, how do i fix this problem? is it the bearings inside and how much will it cost to repair? thanks in advance , very scared person!!
  • Washing Mach... Master
  • 17,129 Answers
The cost depends a lot on the location you are in but not to worry this seems to be a mechanical fault and all what is required is good skill to remove the assembly and check , replace the bearings, check the shaft, bushes, seals for wear and reset.
With a manual check you can observe the wobbling of the drum and will prove that this is not steady due to the failure of the mechanical system comprising the spares mentioned.
Posted on Apr 01, 2011
A squealing sound from the drum when rotating
There are plastic nylon guides located on the front of the drum. Most likely they are wore down and the drum is rubbing against metal. You can get these online at appliance centers or at a local appliance center. All you need is the model number normally found inside the door frame.
Mar 09, 2012 | LG WM1814CW Front Load Washer
My Haier 6kg AA washing machine keeps coming up with error code 1 what's the problem?
Hi Carys from retired Englishman in SW France,
For Haier error code 1 states 'door is not properly shut 20 seconds after program has started'
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 14, 2011 | Haier Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Hi, we have a Beko 6kg AA WMA652S and its not spinning. It won't spin during wash or at the end. Any idea what's wrong?
the problem might be the panel or it might be the washer pump that brings water out after wash
Jul 07, 2011 | Washing Machines
Hi,my haier washing machine is making a terrible noise when the wash cycle goas on spin and then the drum is hiting the door causing it to spark it sounds as if somthing is stuck between the drum and the...
Sounds like bearing and spider have gone, spider is the support on the drum which goes through the tub. then the wheel fits onto it. Open the door and see if you can lift the drum, if the drum lifts with a clunk or with ease then this will confirm the problem
Feb 25, 2011 | Haier Washing Machines
Haier 6kg top loader HWMP60TLF Water dripping from top of rubber hose where it connects to bottom of drum. The rubber hose diameter is at 40mm at the drum end and the hose twists through 90 deg and reduces...
have u tryed putting a hose clamp around the 40 mm end?or has it got a small hole in it? please reply 4 more help. i have worked on these machines b4. please turn off power b4 you work on it, don"t want any accidents.
May 08, 2010 | Washing Machines
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Duet metallic rubbing sound
if you've already ck inside front of door boot call repair acess from front can be tricky to almost impossible without removing complete door boot or worse
Sep 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum sounds like it's rubbing against metal
hi there....sounds as if youve got a bra wire etc trapped between the outer and inner drum..open the appliance door and carefully examine the inner drum you will possibly see the offending wire protruding from some one of the holes in the drum...it can either be removed by juggling it out or having an engineer remove it for you regards Sir Galahad
Dec 28, 2006 | Creda W120VW Front Load Washer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
